rattle coming from the tongue that touches to the clutch cylinder!!
5 replies to this topic
#1 98legacywv
98legacywv
    USMB Regular
  • PipPipPip
  • 37 posts
  • Centreville
Posted 29 April 2005 - 10:43 AM
My car is now making a wierd rattling noise where the clutch cylinder pushes the rod against the tongue (for lack of better word) that comes out of the transmission. Since the car is a hydraulic clutch is it just and adjustment? or am i headed for more problems.. as if i havent had enough with this car already..
#2 Gnuman
Gnuman
    1000+ Super USER!
  • 1,399 posts
  • Richmond, CA
Posted 29 April 2005 - 12:43 PM
fork is a better word. . . that "tounge" is the clutch release fork, and really should not be rattling. Is there a good level of fluid in the resivior? has the cluch been slipping at all? Is there residue from a possable fluid leak in the area?
#3 MDW25gt
MDW25gt
    USMB is life!
  • 131 posts
  • Cincinnati
Posted 30 April 2005 - 09:03 AM
I had the same problem. turned out it was the slave cylinder. easy to change and costs about $75. (2) bolts and the hose, then bleed the system. Seems the spring gets lazy or the cylinder bore gets fouled. this inhibits the piston from maintaining contact with the fork.
#4 98legacywv
98legacywv
    USMB Regular
  • PipPipPip
  • 37 posts
  • Centreville
Posted 02 May 2005 - 09:29 AM
there are no signs of leaking.. my clutch doesnt slip but you dont have to push very far on the pedal before it does... i think it worn but not worn out.. i figured it was a problem with the slave cylinder or the fork itself because the rubber or plastic grommet around the fork entrance to the tranny is kinda of old and in bad shape.
#5 Scottbaru
Scottbaru
    Eat, Live, Breath Subaru
  • 312 posts
  • Holland
Posted 02 May 2005 - 11:03 AM
<snip>the rubber or plastic grommet around the fork entrance to the tranny is kinda of old and in bad shape.
Mine too, I've asked before if there's a source for new ones. I fear if I leave that hole open, salty road slush will find it's way in there.
#6 Al_SemC
Al_SemC
    USMB Regular
  • PipPipPip
  • 122 posts
  • Rochester
Posted 02 May 2005 - 12:39 PM
Check the play between the fork and the slave piston. It should be 1/8"-5/32", according to my book here.
