05blusub Posted May 5, 2005 Share Posted May 5, 2005 The chime is driving me crazy. I tried the " turn key to start position, then wait for chime, then inset and take out of buckle 20 times" I read these instructions on another Subaru message board, but can NOT get it to work. Advice? Heard of another way? Thinking of using my wire cutters soon..... Eric Quote Link to comment Share on other sites More sharing options...
brus brother Posted May 5, 2005 Share Posted May 5, 2005 Worked for me. Turn key to ON position. DO NOT start engine. Quickly buckle and unbuckle driver's side seatbelt 15-20 times rapidly then turn key to OFF position and remove key. The next time you start the car the chime will chime 5 times and then stop. The chime will still chime 5 times each time you start the car. Quote Link to comment Share on other sites More sharing options...
05blusub Posted May 5, 2005 Author Share Posted May 5, 2005 OK, I am going to try it again. Hope it works for the passanger seat as my beagle sits there and the d!#@ chime keeps him from catching his 20 hours of sleep. bluesharpfor30yrseric Quote Link to comment Share on other sites More sharing options...
SubaruLegacy2003 Posted May 5, 2005 Share Posted May 5, 2005 Put the dog in the back seat. Quote Link to comment Share on other sites More sharing options...
frag Posted May 5, 2005 Share Posted May 5, 2005 Buckle the seat belt behind the dog. Quote Link to comment Share on other sites More sharing options...
05blusub Posted May 5, 2005 Author Share Posted May 5, 2005 behind the dog, back seat...it's the damn chime thats the problem even without the dog. OK I am obsessing and going out to try the fix for the 5th time. Quote Link to comment Share on other sites More sharing options...
brus brother Posted May 5, 2005 Share Posted May 5, 2005 It should work for the passenger (er dog) side as well once you've performed the steps as descibed above. There is actually a TSB from SOA for this but it doesn't give the details on the NHTSA site. Anyway, it should work for you since I was successful and my wife says I am barely smarter than dirt. Quote Link to comment Share on other sites More sharing options...
Scottbaru Posted May 5, 2005 Share Posted May 5, 2005 Is your objective to be able to drive without wearing your seatbelt and without the annoying chime? Quote Link to comment Share on other sites More sharing options...
05blusub Posted May 5, 2005 Author Share Posted May 5, 2005 unlike Pavalovs(sp) dog, I do not need a bell to remind me to wear my seat belt, and yes, wearing a seat belt saved my life once..I always wear one. Back to that chime that won't quite....... Quote Link to comment Share on other sites More sharing options...
Scottbaru Posted May 5, 2005 Share Posted May 5, 2005 I fear snipping might not do the trick, the circuit usually needs to be connected through the seat belt latch. Of course this one may be different. You'll probably need to make a connection between the parallel wires under your seat. A scotch splice would work well, you'd have to cut it out a little to have two wires run completely through. It would be simple, clean, and easy to remove. Just a thought. Quote Link to comment Share on other sites More sharing options...
05blusub Posted May 6, 2005 Author Share Posted May 6, 2005 thank you for the advice...I just may try that. Quote Link to comment Share on other sites More sharing options...
Marco Polo Posted May 31, 2005 Share Posted May 31, 2005 I just registered with this Board specifically to find relief on this exact issue! 'Tried the "cold clicks" method, and it worked. Thanks, USMB. P.S. I habitually and steadfastly use and require use of seat belts. Indeed, this pattern of usage is one reason why the chime is superfluous. And, there are situations in which the chime is a needless annoyance. Packages on the front seat, service procedures, moving from one area of a shopping mall to another. Quote Link to comment Share on other sites More sharing options...
