Novakaine Posted May 5, 2005 Share Posted May 5, 2005 Okay, so here is the situation. My car manual says to use dextron 2 ATF, fine. But I can't find dextron 2 anywhere, and the guy at napa auto parts says that dextron 3 is the new better replacement for dextron 2. Is that true? also what kind of ATF would you guys recommend, castrol, redline? Synthetic? Synthetic blend? I am really confused...help. Thanks Quote Link to comment Share on other sites More sharing options...
deiscient Posted May 5, 2005 Share Posted May 5, 2005 When I replenished my PS pump recently I used Citgo Dexron III. The back label clearly states that it is acceptable wherever Dexron IIE or Dexron II is required. FWIW, in the ATF section of Autozone here I could not find any of those other Dexron types either although there was an ample supply of Ford and Chrysler specced fluids in addition to the Dex. (that is a GM standard, I think). I suspect this question is an academic consideration only with no practical impact, much like the discussion of the various API motor oil classes yesterday. Quote Link to comment Share on other sites More sharing options...
scoobdude Posted May 5, 2005 Share Posted May 5, 2005 try this link www.bobistheoilguy.com i have cruised that forum many times in search of oil related questions. its awesome and very informative. its also alot like this board in the sense it requires a mature audience. good luck though Joe Quote Link to comment Share on other sites More sharing options...
Novakaine Posted May 5, 2005 Author Share Posted May 5, 2005 scoobdude, i appreciate the link and am checking it out right now. Thanks for the info guys. Quote Link to comment Share on other sites More sharing options...
