A challenge has been issued...Dyno results
38 replies to this topic
#26 avatar382
avatar382
    USMB is life!
  • 182 posts
Posted 12 May 2005 - 04:59 PM
I dont have a lagacy VF11 turbo. I have the STOCK VF7...and was running 15 PSI. If you keep boost At or UNDER 11 PSI...you will be fine for infinity. I have run the entire Dragon and Cherohala skyway 100% at 11 PSI. Thats QUITE a beating on the car. the dragon is 11 miles, 318 turns, tight twisty road course style perfection. The Skyway is about...of...25 miles if ultra high speed road course style stuff. pretty much 85% of the Skyway is WOT....where as the Dragon is about 60%. I had no problems keeping up with a stock STi on the Dragon...skyway was...well, more of a problem but he never got more than 1/4 mile out front.
You will be safe with a VF11 at 10 PSI im sure of....especially if you've got a good intercooler setup. With no IC? Dont run more than the stock level...wish is 6.5~8 psi.
We shall test that VF11 safe at 10PSI in less than 4 weeks :lol:
#27 WJM
WJM
    SUBARU
  • 7,828 posts
Posted 12 May 2005 - 07:07 PM
GOOD. I'll be there for SURE now. Along with some ubber special Top Speed stuffs... :banana:
#28 Myxalplyx
Myxalplyx
    Old Wise and Dumb
  • 1,838 posts
  • New Castle
Posted 12 May 2005 - 10:36 PM
"Re: A challenge has been issued...Dyno results"
Nice numbers Will! I am taking on your challenge. I have 3 things left to do.
1: Get an upgraded fuel pump,
2: Get upgraded clutch (Like you pointed out to me in a post/thread),
3: Remove the wet nitrous kit from the XT6 to the RX Turbo....
Here's my plan of attack. Boost will remain stock when running nitrous. When nitrous isn't run, boost will be bumped up but I'll use the fuel flow from the nitrous kit for extra fuel (with no nitrous being injected). If it's too lean, I change the fuel jetting. Too rich, change the fuel jetting and adjust fuel pressure. Welp, there you have it. I've just been moving too slow to get this done lately. The challenge is on. Need some excitement around here. :drunk:
I've been goofing off playing with the XT6 anyways.
#29 Myxalplyx
Myxalplyx
    Old Wise and Dumb
  • 1,838 posts
  • New Castle
Posted 12 May 2005 - 10:47 PM
BTW: Here was the last test nitrous runs I was doing with the XT6 at a 50hp shot. I want to go up to 75+ but the wiggly lines concern me. Retarding the ignition made things worse (more wiggly)....sooo. Perhaps I should go with a higher jetting to go for the challenge. Hey, you didn't say I have to stay N/A or go boosted right? :brow:
Posted Image
Posted Image
#30 kingbobdole
kingbobdole
    Mr. XT-6
  • 1,654 posts
  • Longmont
Posted 13 May 2005 - 02:10 AM
Will, clear your box 'o PMs
#31 WJM
WJM
    SUBARU
  • 7,828 posts
Posted 13 May 2005 - 10:43 AM
send email! wmaham1701@hotmail.com
Kevin...are those 200 hp numbers at the wheels? on the XT6 N/A?
#32 Do It Sidewayz
Do It Sidewayz
    Subaru Fanatic!
  • 464 posts
  • Toronto, Ontario
Posted 13 May 2005 - 06:34 PM
my VF-11 will pull like a bear!
I had it with stock wastegate, and it would pull 6 PSI, and would hang right with our other race car running the stock turbo and 11-12 PSI
I upped the boost a little to 8-9 PSI and the thing flew. it would roast the same other car down the straight.
I was running a Supra Turbo Intercooler, big hood scoop, Cone Filter, straight exhaust, custom equal length fuel rails, and custom made header.
and yes...my hood scoop is big...
Posted Image
#33 Myxalplyx
Myxalplyx
    Old Wise and Dumb
  • 1,838 posts
  • New Castle
Posted 13 May 2005 - 07:05 PM
Nah! Just 100hp N/A and about 140hp with the nitrous.
#34 iluvdrt
iluvdrt
    Overland Brat Builder
  • 987 posts
  • Oceanside, Ca
Posted 13 May 2005 - 07:19 PM
I have been toying with the idea of getting my block "o-ringed". Basically they take the block and counter bore a ring around the cylinder about .030" deep then insert a metal o-ring on it before mounting the head. I know the diesel engines have been doing it to run Huge boost levels(over 100 psi) and they say it will never blow a H/G unless the heads push off the block. I think that could be fixed with some ARP heads studs though.
#35 Myxalplyx
Myxalplyx
    Old Wise and Dumb
  • 1,838 posts
  • New Castle
Posted 13 May 2005 - 08:52 PM
Darn it! Someone take Will up on the challenge. :banana:
DoitSideways, that's an interesting car. Color them draws attention.
#36 Myxalplyx
Myxalplyx
    Old Wise and Dumb
  • 1,838 posts
  • New Castle
Posted 13 May 2005 - 08:55 PM
Question! How much extra boost can you theoretically get away with using c16 gas if your max boost is reached at ....say 15psi with 93 octane before detonation?
#37 Do It Sidewayz
Do It Sidewayz
    Subaru Fanatic!
  • 464 posts
  • Toronto, Ontario
Posted 14 May 2005 - 12:30 AM
with just race fuel......ZERO extra boost. The problem isn't really detonation. it's heat. By running so lean you are literally melting the pistons.
race fuel doesn't gain you air/fuel ratio. Just has more resistance to detonation.
and yeah it's painted to attract attention, it's a dedicated race car
#38 Ross
Ross
    Can't be bothered
  • 1,865 posts
  • Christchurch, New Zealand
Posted 14 May 2005 - 01:49 AM
Sounds like you guys want some water injection!
#39 WJM
WJM
    SUBARU
  • 7,828 posts
Posted 14 May 2005 - 08:09 AM
Methanol.
