Orange dust around a/c compressor
Yes, it's normal. Just about every older Subaru I've seen has red-orange dust all over the area by the A/C compressor.
I presume it's friction material off the A/C clutch.
To me that would indicate a bearing which is dry and already bad. Like the same colored powder when a U-joint is shot, it is metasl which has been turned into powder and is now rusting.............
swi66
swi66
The compressor runs very quietly; and no vibration... the area where the dust is coming from is not hot either.
That stuff is, in fact, the metallic "dust" resulting from thousands of on-off cycles of the compressor clutch. It builds up at the front of most compressors but it's more obvious on a longitudinally-mounted (conventional front-to-rear) engine than it is on a transverse-mounted (side-to-side) engine just because of wind blowing it back....
