cabron Posted May 10, 2005 Share Posted May 10, 2005 I have an 01 legacy Gt Ltd. Recently I have noticed an orange dust emanating from the front of the compressor. I am new owner; and thus not sure if this is normal. Any advise? Thanks Quote Link to comment Share on other sites More sharing options...
TheBrian Posted May 10, 2005 Share Posted May 10, 2005 Yes, it's normal. Just about every older Subaru I've seen has red-orange dust all over the area by the A/C compressor. I presume it's friction material off the A/C clutch. Quote Link to comment Share on other sites More sharing options...
swi66 Posted May 10, 2005 Share Posted May 10, 2005 Yes, it's normal. Just about every older Subaru I've seen has red-orange dust all over the area by the A/C compressor.I presume it's friction material off the A/C clutch. To me that would indicate a bearing which is dry and already bad. Like the same colored powder when a U-joint is shot, it is metasl which has been turned into powder and is now rusting............. swi66 Quote Link to comment Share on other sites More sharing options...
cabron Posted May 10, 2005 Author Share Posted May 10, 2005 To me that would indicate a bearing which is dry and already bad. Like the same colored powder when a U-joint is shot, it is metasl which has been turned into powder and is now rusting............. swi66 The compressor runs very quietly; and no vibration... the area where the dust is coming from is not hot either. Quote Link to comment Share on other sites More sharing options...
mwatt Posted May 11, 2005 Share Posted May 11, 2005 The compressor runs very quietly; and no vibration... the area where the dust is coming from is not hot either. That stuff is, in fact, the metallic "dust" resulting from thousands of on-off cycles of the compressor clutch. It builds up at the front of most compressors but it's more obvious on a longitudinally-mounted (conventional front-to-rear) engine than it is on a transverse-mounted (side-to-side) engine just because of wind blowing it back.... Quote Link to comment Share on other sites More sharing options...
