Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
ea82 2wd to d/r 5spd 4x4 conv, can i keep existing flywheel, and gastank?
#1
Guest_subu luvr_*
Posted 06 September 2003 - 03:05 PM
found d/r 5spd 4x4 in sedan
wanna know if i need to pull the flywheel from the donor car,
or if i can be slack...
does the starter vary between different trannies?
wagon gas tanks are same 2wd/4wd?
#2
Posted 06 September 2003 - 03:08 PM
#3
Posted 07 September 2003 - 05:21 AM
take te entire rear suapension as one piece, so the mont for the diff is there, and the rear trailing arms that have the 4wd hubs.
#4
Posted 07 September 2003 - 07:14 PM
Might need to drill some holes thare are not there for the 4WD rear main crossmember assembly. I had to drill holes out for the rear diff hanger. YOu will see exactly where you need to drill; if they are not already drilled out for you. Center carier bearing for the drive shaft will be interesting too. I have not got that far. I'm leaning twoard getting mine modified into a solid drive shaft and skipping the center carier bearing. As usual however I'm sure funding will over ride my desires.. and I'll end up just trying to bolt in the OEM drive shaft
I'm about half done with this very same swap. All I can say is may the force be with you
#5
Guest_subu luvr_*
Posted 07 September 2003 - 10:28 PM
will advise...
#6
Posted 08 September 2003 - 01:08 AM
#7
Posted 08 September 2003 - 01:18 AM
#8
Posted 08 September 2003 - 01:25 PM
at least being a 5spd to begin with you can use the same mounts and crossmember. the only trouble spot will be the driveshaft mount.
what you got is a little less involved than the 2wd auto to 5spd 4wd that we did, so i know for a fact you can do it with no problem
#9
Posted 08 September 2003 - 01:30 PM
#10
Posted 08 September 2003 - 02:11 PM
its opssible to just drill the first layer, and put a captive nut behind it through the hole where the bumper mounts fit into(on a wagon)
if you go thru the floor, use a fat washer, as it will want to pull thru as you torque it down. i would suggest using the nuts with the nylon insert so it will stay tight without a lot of torque
#11
Posted 08 September 2003 - 03:14 PM
all of the different styles of starters i have seen will mount the same
True, they do mount the same.. But when I did my 5 spd conversion, and tried to use the longer 2wd starter, the vacuum module on the tranny got in the way and the starter wouldn't mount.. had to dig out my spare, which thankfully was a 4wd starter with the shorter body
I know you are doing D/R, wehreas I was only doing the S/R swap, so the longer body starter may fit, as you prbably don't have that vacuum module to deal with(unless you have a diff lock, then you still have to deal owith it)
