Fitting a WRX into a Legacy RS
5 replies to this topic
#1 Sabre75
Sabre75
    New User
  • Pip
  • 2 posts
  • Wellington
Posted 12 May 2005 - 03:24 AM
Hi, I have just dropped a WRX motor into My 91 legacy, I have done the Wiring loom transplant on the intake manifold ( my old loom on the new manifold), Is there anything elst that I should do ie Fuel pump Change the computer over.
The Car is running really well but only boosts to 8lb as I am still running the Legacy computer, Also should I get the Legacy computer Fuel zones remapped?
#2 offroadsubaruguy
offroadsubaruguy
    Subaru Nut
  • 729 posts
  • arvada, colorado
Posted 12 May 2005 - 08:30 AM
i would say that if you have the wrx computer, use it.... its just all around better.....
#3 wagonist
wagonist
    User Awaiting Email Confirmation
  • 949 posts
  • Sydney, Australia
Posted 17 May 2005 - 09:34 AM
I'd be careful doing that. There are some subtle minor changes in the wiring between the Legacy & WRX if you're talking about the series 1 Legacy that is.
#4 EA82Turbo
EA82Turbo
    USMB Regular
  • PipPipPip
  • 90 posts
  • Nelson, New Zealand
Posted 24 August 2005 - 05:51 PM
Hello,
Im thinking of doing the samew conversion. Was it difficult?
Gearbox bolts line up?
Can use standard RS loom?
Also thinking of swap to WRX close ratio gearbox. Do WRX gearboxes fit? Gearbox width the same? spline count to axle the same? EG: can use legacy axles?
#5 wagonist
wagonist
  • 949 posts
  • Sydney, Australia
Posted 24 August 2005 - 08:02 PM
The pre 97 & post 97 gearboxes and engines have some subtle differences.
Fitting a later box onto an early engine is detailed on the Oz Liberty RS forum.
Otherwise, everything is a straight swap over.
#6 UuuPIT
UuuPIT
    New User
  • Pip
  • 4 posts
  • Ottawa
Posted 26 August 2005 - 08:42 AM
I have an opertunity to fit a STI v7 engine in my 92 Legacy.
If I keep my auto tranny, will the new engine blow the auto tranny?
