Are new struts still available?
14 replies to this topic
#1 Subieguy
Subieguy
    Subaru on the brain!
  • 915 posts
  • Paso Robles, California
Posted 17 May 2005 - 11:12 PM
I am looking for new struts for my 78 Brat. Are they even made any more? I am looking to replace the rear shocks too. Help me out please! I am trying to get my Brat good enough to take it down to Pismo Beach and try it out. Got some work to get it to that point but this along with a good drivers side CV axle would be a good start. Thanks.
#2 Caboobaroo
Caboobaroo
    USMB Drunk
  • 7,157 posts
  • Oregon City
Posted 17 May 2005 - 11:34 PM
If I were you, I would swap in EA81 struts for the front since they're a lot easier to come by and you can get the adjustable ones. Almost a direct bolt in but one of the brackets that holds it into the knuckle is different then the EA71. Also, you can use EA81 front axles in place of the EA71, just about 1/2" difference in length but can be used.
#3 moosens
moosens
    Vintage Subathusiast
  • 1,964 posts
  • Bridgeport CT
Posted 18 May 2005 - 04:11 PM
THey all still show up on eBay all the time.
#4 Seahag1978
Seahag1978
    1000+ Super USER!
  • 1,390 posts
  • Witch City
Posted 18 May 2005 - 08:44 PM
I got rear shocks for my '78 on eBay for $24.95 a pair + ship.
If you need them in a hurry...
www.classicgarage.com
They had the front struts for my '78. More expensive but still deeply discounted from list.
#5 DaveAP
DaveAP
    Subaru Fanatic!
  • 387 posts
  • Prescott, Arizona
Posted 18 May 2005 - 11:44 PM
How did you overcome the difference in brackets?
Is the ea81 axle the shorter of the two? I have two remans from Checker that are barely long enough to use.
#6 SUBARU3
SUBARU3
    Moderator
  • Moderator
  • 2,842 posts
  • Dallas, Ft. Worth, Texas
Posted 19 May 2005 - 02:25 AM
The rear shocks are the same as ALL gen 1 cars. 2WD OR 4WD.
I might have a set of rears. Are you interested?
Todd
#7 bajavwnsoobnut
bajavwnsoobnut
    Insane Rally Freak
  • 3,789 posts
  • Milwaukie
Posted 22 May 2005 - 10:17 AM
KYB still makes them but look for the listing under 1980 or 1981 brat for the struts and shocks cause the listings that most places will have will only date back to 80 and luckily gen 1 brats were made for those 2 years
#8 Subieguy
Subieguy
  • 915 posts
Posted 22 May 2005 - 08:37 PM
Can you point me in the right direction as to where I might find the KYB struts. I did a little searching on the internet and came up with nothing. Thanks.
#9 SUBARU3
SUBARU3
    Moderator
  • Moderator
  • 2,842 posts
Posted 22 May 2005 - 08:47 PM
I'm told that the 2 WD inserts will also work in the 4WD strut. I have some for sale here.
http://www.ultimates...ead.php?t=36653
#10 Caboobaroo
Caboobaroo
    USMB Drunk
  • 7,157 posts
  • Oregon City
Posted 22 May 2005 - 09:48 PM
Basically there's a clamp on the knuckle that "clamps" the strut into the knuckle and then there's another bracket on the strut that a bolt runs through and into the knuckle. If I remember correctly, I turned the EA81 strut into the same direction as the EA71, bent the bracket a little bit and it worked. Even if you don't use the bracket, I'm pretty sure the clamping force of the knuckle would be sufficiant enough for everyday street driving.
As for the axles, the EA81 axle is about 1/2" longer then the EA71...
#11 bajavwnsoobnut
bajavwnsoobnut
    Insane Rally Freak
  • 3,789 posts
  • Milwaukie
Posted 23 May 2005 - 01:07 AM
just try the local parts stores and if need be tell them to look through their books and also try the other brands too for a replacement strut
#12 DaveAP
DaveAP
    Subaru Fanatic!
  • 387 posts
  • Prescott, Arizona
Posted 23 May 2005 - 02:11 AM
(a little off thread, but...) I have two axles on my '78,not long enough to even put the flat washer on after the cone washer. I haven't done anything about it yet as the '78 is off the road as of now. I figure the ends were buggered up, they trimmed the ends and chased the threads.
#13 SUBARU3
SUBARU3
    Moderator
  • Moderator
  • 2,842 posts
Posted 24 May 2005 - 02:32 AM
Did you get your rear shocks?
#14 wrw166
wrw166
    New User
  • PipPip
  • 26 posts
  • las vegas
Posted 24 May 2005 - 10:51 AM
i put fwd strut tubes on my 1980 4wd. they were koni adjustable from:
DCS consulting:
Posted Image1755 Mission Rd., 2nd FloorPosted ImageSouth San Francisco, CA 94080+1220Posted ImageUS Posted ImagePosted ImageMain Phone: (650) 756-3533Posted ImageFax : (650) 756-5533Posted ImagePosted ImageWholesale distributor of Koni obsolete and discontinued Koni shock absorbers. Exporter to Australia. +++++++++++++++++++++++
they were old stock and 2 for $17.50 on ebay. they sold me a third for $5.
the first on i instlled clunked. so i had to take it apart and put a spacer between the inset and the bottom of the tube ( a 1" junk brass nut) now they're fine. a little too stiff at 1/2 setting.
these things arn't too mysterious. i'd try any Subaru stuff. stay awayfrom Monroe! hope ths is helpful.
Posted Image
#15 82bratavenger
82bratavenger
    USMB Regular
  • PipPipPip
  • 109 posts
  • Malaga, WA
Posted 27 May 2005 - 12:04 AM
I just bought KYB shocks and struts for my '82 Brat at my local Foriegn parts store. They are a parts plus dealer. Cost me about $240 after tax and they shipped in the next day.
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
