I have a EJ25 non-Turbo engine that I would like to convert to a Turbo.. This engine is going into a off road project car, so I will be eliminating most of the hoses and pollution stuff.
I believe that I will need to swap out the higher compression pistons for lower compression pistons. Will I need to do anything to the heads? Also,
Who sells a decent low compression pistons?
Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
Converting to a Turbo?
Started by
OhChit
, May 25 2005 09:17 AM
6 replies to this topic
#1
Posted 25 May 2005 - 09:17 AM
#2
Posted 26 May 2005 - 10:36 AM
Help-ppppppp Anyone gots any idea's on what's needed?
#3
Posted 26 May 2005 - 04:34 PM
Too much. Find a turbo car and use it. It will be cheaper than engine rebuild, ecu and harnesses. Also I think the turbo cars come with special scotchguarded seats. It makes them easier to clean.
d.
d.
#4
Posted 26 May 2005 - 05:24 PM
I can’t switch the engine. It’s a off road project car, and I’ll be running an aftermarket ECU, so no issues with vacuum hoses or pollution concerns.
The engine needs to be a Subaru 2.5 SOHC engine. And since I can’t locate a Turbo version of the 2.5 SOHC at a reasonable price. I’m forced to convert a non-Turbo engine to a Turbo. Oh-ooo by the way I also need to covert a DOHC engine to SOHC heads.. So it looks like I need to replace the pistons with low compression pistons, and the heads with SOHC heads. Any thoughts?
#5
Posted 26 May 2005 - 05:43 PM
All that would work, but turbo blocks are stronger, and you won't be able to run much boost reliably. You'd be able to make more power for less using a 2.0 or 2.2 turbo block.
#6
Posted 26 May 2005 - 05:53 PM
Ok.. I hear you on the Turbo Block, but the 2.2 Turbo engine was only made for about 4 years and isn't easily found. As for the 2.0 I have one of those but hate to rape it. So it's on with the search for a 2.5 turbo, or maybe in my case convert one?
By the way if anyone has any parts or an engine that they want to sell please feel free to let me know.
Thnaks Jon
Thnaks Jon
#7
Posted 27 May 2005 - 01:46 AM
check out www.rallitek.com , i think they sell 2.5 turbo kits.
