1986 GL manual 4WD switch
9 replies to this topic
#1 yorab
yorab
    USMB Regular
  • PipPipPip
  • 71 posts
  • State College
Posted 26 May 2005 - 12:34 PM
I was putting my dash back together after a blower repair when I decided to secure the panels around my gear selector stick and 4WD selector stick. They have been loose and make a terrible 'plastic rubbing plastic' sound. While investigating I found that the switch located at the base of the 4WD stick was broken. I'm not exactly sure what the switch does or where to find a cheap (cheaper than dealer) replacement. Any thoughts?
James
#2 subynut
subynut
    EJ Powa!
  • 1,421 posts
  • Sierra Vista, AZ
Posted 26 May 2005 - 05:02 PM
Sounds like you found the Lowrange switch. All that does is turn on an indicator in the dash to tell you that your in 4lo. Mine died a few years back, havn't found a good replacement besides the dealer, so, I do without. Ain't gonna hurt a thing.
#3 yorab
yorab
    USMB Regular
  • PipPipPip
  • 71 posts
  • State College
Posted 26 May 2005 - 10:04 PM
I disconnected the switch and removed it, but the indicator on the dash still displays 4WD when it's in 4wd and goes out when I go back to fwd. Does the switch differentiate between 4 HI and 4 LO?
#4 subynut
subynut
    EJ Powa!
  • 1,421 posts
  • Sierra Vista, AZ
Posted 26 May 2005 - 11:52 PM
There are 2 switches:
One is the 4LO switch, that's the one on the shift linkage under the boot that we are talking about.
The other is mounted on the tranny, that's the 4WD indicator.
They just to tell you if you are in 4WD and if your in 4LO.
#5 yorab
yorab
    USMB Regular
  • PipPipPip
  • 71 posts
  • State College
Posted 27 May 2005 - 05:49 PM
Thanks for the info Subynut.
#6 subynut
subynut
    EJ Powa!
  • 1,421 posts
  • Sierra Vista, AZ
Posted 27 May 2005 - 09:25 PM
No probelm. Glad to help out fellow Suby owners!
#7 BobBrumby
BobBrumby
    Subaru Nut
  • 583 posts
  • Brisbane, Australia
Posted 27 May 2005 - 10:58 PM
when i removed my centre console so fix sterio i found that the previous owner had zip tied and glued the 4 lo switch back into position. maybe you could give that a try if you cant go pull one.
#8 yorab
yorab
    USMB Regular
  • PipPipPip
  • 71 posts
  • State College
Posted 28 May 2005 - 08:47 PM
I might be able to get away with the zip strip and glue method. The plastic housing is broken but the metal contacts seem to be in good shape.
#9 yorab
yorab
    USMB Regular
  • PipPipPip
  • 71 posts
  • State College
Posted 01 June 2005 - 10:26 PM
I called the dealer today out of curiosity. The 4 LO switch is only $15. I couldn't believe it. I went ahead and ordered one.
#10 subynut
subynut
    EJ Powa!
  • 1,421 posts
  • Sierra Vista, AZ
Posted 02 June 2005 - 10:31 PM
15? Wow. Almost makes me wanna fix mine.
