ATV's use 4-140mm lug patern? ( ATTN:snowman)
15 replies to this topic
#1 soobme
soobme
    Subaru Master
  • 1,871 posts
  • Medford OR
Posted 08 September 2003 - 10:59 AM
Is it true, 4-140mm is a comman ATV lug patern?!?
#2 MorganM
MorganM
    Do you Subaru?
  • 8,390 posts
  • TwinCities
Posted 08 September 2003 - 11:04 AM
This is true; some ATVs share the same bolt pattern.
#3 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
  • Madison/Milwaukee, WI
Posted 08 September 2003 - 12:20 PM
i read that suzuki used the soob lug pattern.
#4 Qman
Qman
    Happiness is... no lag!!
  • Moderator
  • 11,119 posts
  • Sumner
Posted 08 September 2003 - 01:17 PM
Yes, most use the 4x140mm pattern. Problem being the biggest wheels they use are 10 or 12". You thought you had clearance issues now.
#5 soobme
soobme
    Subaru Master
  • 1,871 posts
  • Medford OR
Posted 08 September 2003 - 01:25 PM
I know that National Tire&Wheel sells monster tires and wheels for ATV's. I'm thinking of this for a good set of sand tires and wheels. I think I will go check out there site and see what I can find out.
#6 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
Posted 08 September 2003 - 01:27 PM
atv big boofy tires are rated for lower psi. hope they dont pop the beads with the weight of a soob. but try it out, you may never know!
but the atv tires are not radial, are not dot approved, and are illegal and probably unsafe for paved road usage, but they will be a lot of fun off road!!!
#7 MorganM
MorganM
    Do you Subaru?
  • 8,390 posts
  • TwinCities
Posted 08 September 2003 - 01:28 PM
Be sure and check the max load capacity on any tires you find.
#8 soobme
soobme
    Subaru Master
  • 1,871 posts
  • Medford OR
Posted 08 September 2003 - 01:32 PM
12" wheels are the bigest I can find, I don't think they would clear my calipers front and rear:banghead:
They sure do have some kick rump roast tires for 'em! 27" Swamper Vampires!
#9 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
Posted 08 September 2003 - 02:22 PM
well, at least you can put subaru wheels on an atv in hopes that you can register it as a motorcycle (dot approved tires, turn lights, brake light, speedometer)
#10 Snowman
Snowman
    Midnight Passenger
  • 3,538 posts
  • Haines
Posted 08 September 2003 - 02:48 PM
I had actually considered ATV tires before, but found the same problem, they don't make big enough wheels for a subaru, and the weight rating would be different. Also, usually only the front wheels use a 4x140 pattern (on the rear of my suzuki, it's a five lug), so only front rims would work.
#11 Sweet82
Sweet82
    Elite Master of the Subaru
  • 3,274 posts
  • Salt Lake City
Posted 08 September 2003 - 03:03 PM
Folks do use ATV tires on Subarus!
The Auzzies have been doing it for several years now. Seems to work fine for them.
A 12" rim is suppose to clear/fit on your old Subie:brow:
This is exactly what my buggy plans call for.:D
I'm looking at having some 12" rims custom made by Stockton Rim or (using agricultural blanks and welding in a center). This would allow me to use ATV tires and not ATV rims. I'm not convinced the rims would hold up to abuse? I have spoke with several dealers and they questioned the strength too.
A 26X12X12 (6ply) is suppose to be the same as your factory tire. This would allow you to keep your gearing and have a lot of rubber between a rock and your rim.
I'm planning on doing it!!!!!!!!!!!!!!
For what it's worth,
Glenn
82 Hatch, transforming...wants ATV tires : :temper:
01 Forester, jealous........:boohoo
#12 cole098
cole098
    Subaru. It's a sickness
  • 429 posts
  • pottsville,pa
Posted 08 September 2003 - 05:21 PM
Didnt someone say at one time that a trailer rim in a 14 was available.....Joe
#13 baccaruda
baccaruda
    YOUR FAVORITE MOD
  • Moderator
  • 6,950 posts
  • SpoVegas, WA
Posted 08 September 2003 - 05:27 PM
clearance issues? no problem. just swap some drum brakes on front and rear :banana:
#14 GeneralDisorder
GeneralDisorder
  • 21,922 posts
  • Portland
Posted 08 September 2003 - 05:58 PM
Just drill out some chevy 6 lugs - it's so much easier than trying to find rims for the 4x140. And you can get em for like $25 each BRAND NEW.
#15 Caboobaroo
Caboobaroo
    USMB Drunk
  • 7,157 posts
  • Oregon City
Posted 08 September 2003 - 08:54 PM
or know where a pug junkyard is:brow: go lookin for some rims...hmm maybe I'll have to do that sometime this week:drunk:
#16 bushbasher
bushbasher
    exhaust fume addict
  • 1,707 posts
  • Sooke B.C. Canada
Posted 08 September 2003 - 10:55 PM
everyday i see this green peugot in town, and I keep wishing it's engine will blow up or something, so that I can go steal the rims off of it once it gets to the yard! I'm so evil :madder:
