Stu Baker Posted May 27, 2005 Share Posted May 27, 2005 96 Outback w/ 120k. Leaking oil where the timing belt is. Was told that it's an oil seal where the timing belt is. No problem, been putting oil 10W-40 (about 1/2 qut.) about every two weeks. Problem now I've noticed is that at idle...say at a traffic lite, the oil light comes on then goes out when u accelerate. This happens when the car is at opert. temp.. I check the dipstik and it's "safe". There must be oil in the pan if I'm getting a reading? I don't want to go to the shop since I've already spent alot of cash just getting this car running to pass inspection. Adding oil I can deal with...for now. I doubt it's a faulty bulb. I think MAYBE at idle the oil is Not flowing??? Suggestions would be great. I bought this car cheap and like I said, I already spent enough $ on repair's to get it inspected. Thank You, sambo Quote Link to comment Share on other sites More sharing options...
Buddy Posted May 27, 2005 Share Posted May 27, 2005 hey sorry to burst your bubble but you have to post this in the new generation subaru forum. i wish i could help but i don't know anything about new school soobs. ( man i wish i did though). Quote Link to comment Share on other sites More sharing options...
ShawnW Posted May 27, 2005 Share Posted May 27, 2005 That light doesnt come on until the car has less than 3-5 PSI! Don't chance this, you have a problem. Replace the timing belt and have the oil pump resealed. Quote Link to comment Share on other sites More sharing options...
Olnick Posted May 27, 2005 Share Posted May 27, 2005 Agree with ShawnW--you'd be wise to change the timing belt, replace the crank and cam seals and reseal the oil pump (tighten the backplate screws, new o-ring and sealant). Might want to replace the waterpump while you're in there too, a good preventative measure. Search the board--there's a lot of good info here. Quote Link to comment Share on other sites More sharing options...
Stu Baker Posted May 27, 2005 Author Share Posted May 27, 2005 I guess I'm in the incorrect "forum". I should be in the "newer subaru forum"......excuse meeee:rolleyes:! I just registered yesterday, so it'll take me awhile to figure this out. Am I going to be fined?? Because I'm losing oil through the seal I lose pressure which is why light comes on...right? I knew I shouldn't have bought this vehicle. More $! Thank you, sambo Quote Link to comment Share on other sites More sharing options...
frag Posted May 27, 2005 Share Posted May 27, 2005 I guess I'm in the incorrect "forum". I should be in the "newer subaru forum"......excuse meeee:rolleyes:! I just registered yesterday, so it'll take me awhile to figure this out. Am I going to be fined?? Because I'm losing oil through the seal I lose pressure which is why light comes on...right? I knew I shouldn't have bought this vehicle. More $! Thank you, sambo Loosing oil through the cam or/and crank seals will do nothing to lower the oil pressure, but a dried up oil pump O ring or/and a loose oil pump backing plate can. Quote Link to comment Share on other sites More sharing options...
Setright Posted May 28, 2005 Share Posted May 28, 2005 Low oil presure is a sure fire way of killing an engine quick. You have to replace the seals! That light is to be taken seriously. The work involved isn't rocket science, but one or two things are easier if you have the right tools - like removing the crank pulley. Are you confident in DIY? Quote Link to comment Share on other sites More sharing options...
TheBrian Posted May 28, 2005 Share Posted May 28, 2005 2.1psi. Why do car manufacturers do this? Are they saying it's safe to run the engine with 2.2psi of oil pressure? Quote Link to comment Share on other sites More sharing options...
