Hendrik Posted June 1, 2005 Share Posted June 1, 2005 Once again ! I have seen a lot of exemples and pictures for the test connectors under the steering wheel. But none fits the one I have. MPFI , Ecu unit with 3 connectors , distributor without knock sensor unit (only vacuum an pressure control) , just two wires to the coil. The transistor is in the housing. The white connector pair on one side just has a single loop trough , and is always connected since I bought the car , one year ago. Should I disconnect the white ones ? And use the green ones only for ignition timing ? Under the hood are more connectors , see pictures.... They are for testing as well ? Thanks for help ! Quote Link to comment Share on other sites More sharing options...
calebz Posted June 1, 2005 Share Posted June 1, 2005 http://www.ultimatesubaru.org/photos/ Upload your pics there.. Every member gets a little space. Quote Link to comment Share on other sites More sharing options...
Hendrik Posted June 1, 2005 Author Share Posted June 1, 2005 http://www.ultimatesubaru.org/photos/ Upload your pics there.. Every member gets a little space. Thank you , did upload , but what is the right URL for the orginal picture ? I only could find the thumbnail..... Thank for your help ! Quote Link to comment Share on other sites More sharing options...
