Engine Code on 99 Forester - Help
Check Engine Light (CEL) came on about two months ago on our 1999 Forester. The SUV is very hesitant under lower acceleration when moving for the first time or setting awhile. Appears to clear up after gaining speed but CEL is always on. Changed the fuel filer but is still an issue. Had AutoZone pull the code and it was PO335 or PO325.:banghead: Any thoughts? Thanks if advance for your assistance.
The knock sensor retards the engine timing when it detects knocking. This has the effect of decreasing the octane requirement of the engine, and hopefully stops the knocking. Bottom line, the knock sensor is broken, giving a false positive signal, and your engine is retarded.
