30thAnnivSS Posted June 5, 2005 Share Posted June 5, 2005 Check Engine Light (CEL) came on about two months ago on our 1999 Forester. The SUV is very hesitant under lower acceleration when moving for the first time or setting awhile. Appears to clear up after gaining speed but CEL is always on. Changed the fuel filer but is still an issue. Had AutoZone pull the code and it was PO335 or PO325. Any thoughts? Thanks if advance for your assistance. Quote Link to comment Share on other sites More sharing options...
sea#3 Posted June 6, 2005 Share Posted June 6, 2005 PO325 = Knock sensor code - probably needs a new sensor PO335= Crankshaft position sensor - probably needs a new sensor SEA#3 Quote Link to comment Share on other sites More sharing options...
30thAnnivSS Posted June 6, 2005 Author Share Posted June 6, 2005 Great information and thanks. I’m pretty sure it was the knock sensor. Any thoughts on why the knock sensor would cause hesitation under lower acceleration when moving for the first time or setting awhile? Quote Link to comment Share on other sites More sharing options...
The Dude Posted June 7, 2005 Share Posted June 7, 2005 The knock sensor retards the engine timing when it detects knocking. This has the effect of decreasing the octane requirement of the engine, and hopefully stops the knocking. Bottom line, the knock sensor is broken, giving a false positive signal, and your engine is retarded. Quote Link to comment Share on other sites More sharing options...
stevetone Posted June 7, 2005 Share Posted June 7, 2005 ... and your engine is retarded. I don't think that is a politically correct way to refer to a "slow" engine Quote Link to comment Share on other sites More sharing options...
30thAnnivSS Posted June 7, 2005 Author Share Posted June 7, 2005 Thank you for the information everyone and the attempt to make me feel better about my retarded, I mean “slow” engine. Quote Link to comment Share on other sites More sharing options...
