Blower motor resistor 'blow by blow'?
7 replies to this topic
#1 gcleeton
gcleeton
    USMB is life!
  • 139 posts
  • Allegany
Posted 07 June 2005 - 09:51 AM
The blower switch on one of my Legacies has ceased to operate in Positions 1, 2 and 3. Everything works in Position 4. I assume the problem is the blower motor resistor?
Can anybody give me a 'blow by blow' account of how to get at it and replace it please?
Gil
#2 Legacy777
Legacy777
    Moderator
  • Moderator
  • 12,809 posts
  • Houston, Tx
Posted 07 June 2005 - 11:32 AM
remove glove box, look at resister pack straight ahead, remove it, insert new one, and reassemble.
it's very easy.
here's a good pic
http://www.main.expe...mp/DCP_2945.JPG
#3 avk
avk
    My Outback is bigger than yours
  • 964 posts
  • Somerset County, NJ
Posted 07 June 2005 - 11:39 AM
While you're in there, clean AC evaporator and housing with suitable tools.
#4 Legacy777
Legacy777
    Moderator
  • Moderator
  • 12,809 posts
  • Houston, Tx
Posted 07 June 2005 - 05:09 PM
You really can't clean the evap box out just through the hole for the resister pack. I guess you could look in, and see how icky it is though ;)
#5 avk
avk
  • 964 posts
Posted 07 June 2005 - 08:48 PM
I had some leaves, pine needles, seeds etc. on the bottom of the box which I was able to blow out, and also sprayed some mold killer on the evap. It would be a different matter if the evap. core is all gummed up, but it's important to know that the resistor hole gives access to the evaporator.
#6 rdp5008outback
rdp5008outback
    New User
  • PipPip
  • 23 posts
  • Alaska and Seattle
Posted 29 June 2005 - 12:10 PM
Where can I get a replacement resistor pack? How much does the part cost? My 1998 OBS is having the same problem (only working on position 4).
#7 gcleeton
gcleeton
    USMB is life!
  • 139 posts
  • Allegany
Posted 04 July 2005 - 03:19 PM
I got mine from a breaker
Gil
#8 edrach
edrach
    RIP 6/28/14
  • 12,326 posts
  • Bothell, WA
Posted 04 July 2005 - 04:43 PM
The resistor pack is meant to be in the air flow for cooling; if the air flow is restricted in any way, the resistors will overheat and fail pre-maturely.
