timintc Posted June 12, 2005 Share Posted June 12, 2005 What size socket would one use on the drain plug of the front differential of a 2000 A/T Legacy. Its larger than 13/16 and 17mm, 20mm perhaps? Quote Link to comment Share on other sites More sharing options...
Midwst Posted June 13, 2005 Share Posted June 13, 2005 Does it have a squre hole in the middle like the older subarus? Then use a 1/2" drive ratchet, no socket. Quote Link to comment Share on other sites More sharing options...
timintc Posted June 13, 2005 Author Share Posted June 13, 2005 the hole in the middle seems round not squared like the rear Quote Link to comment Share on other sites More sharing options...
Brumby Boy Posted June 13, 2005 Share Posted June 13, 2005 From memory it is 19mm Quote Link to comment Share on other sites More sharing options...
timintc Posted June 13, 2005 Author Share Posted June 13, 2005 its 13/16 if anyone needs to know Quote Link to comment Share on other sites More sharing options...
Andyjo Posted June 14, 2005 Share Posted June 14, 2005 drag your tool set under the car w/ you, and try each one... usually how i work Quote Link to comment Share on other sites More sharing options...
timintc Posted June 14, 2005 Author Share Posted June 14, 2005 found like some sort of metallic sludge on the magnets that are on the inner side of the drain plugs, must be the gears grind up everything metallic that gets shaved off and then it transforms into sludge that is picked up by the magnets, interesting. Quote Link to comment Share on other sites More sharing options...
Midwst Posted June 14, 2005 Share Posted June 14, 2005 I wouldn't worry about a little sludge, but metal shavings would be a big opps! Quote Link to comment Share on other sites More sharing options...
