rwdc Posted June 18, 2005 Share Posted June 18, 2005 Help, I need to remove the radio from my 93 Legacy sedan. I have found and removed the top screws to the cover surrounding the benzel that were behind the cupholder, but cannot figure out how to release the bottom. thanks.... in advance. Quote Link to comment Share on other sites More sharing options...
sregor13 Posted June 19, 2005 Share Posted June 19, 2005 Help, I need to remove the radio from my 93 Legacy sedan. I have found and removed the top screws to the cover surrounding the benzel that were behind the cupholder, but cannot figure out how to release the bottom.thanks.... in advance. Not sure about the 93 but there should be some screws on the bottem sides. You may also need to take aprt part of the Shifter area to get to some of these screws. I know that you have to on my 96 Impreza. The Shifter Plastic either overlaps the peice you need of or it is in the way. Cant remember. If you cant figure it out right away then write back and I will take a flkashlight out to my 94 right now. Quote Link to comment Share on other sites More sharing options...
Legacy777 Posted June 19, 2005 Share Posted June 19, 2005 You need to pull out the ashtray, and there's two screws facing upwards. Remove those, and the trim piece will come out. Quote Link to comment Share on other sites More sharing options...
