mxman70 Posted June 18, 2005 Share Posted June 18, 2005 Does anyone know if I can use a weber carb on a EA82 with a throttle body or are the manifolds for carbs different. Thanks, Pat Quote Link to comment Share on other sites More sharing options...
erik litchy Posted June 18, 2005 Share Posted June 18, 2005 i suppose its possible you have to make a spacer since the throttle body on the spfi has coolant running through the base. it would be better to use a carb manifold in that case becasue then you could use a 2bbl. what are you trying to do? Quote Link to comment Share on other sites More sharing options...
mxman70 Posted June 18, 2005 Author Share Posted June 18, 2005 I'm putting it in a 73 Super beetle.. I'm going for the most simple, least problematic installation possible. Quote Link to comment Share on other sites More sharing options...
erik litchy Posted June 18, 2005 Share Posted June 18, 2005 do you have the right distrubitor already? it would be easier to just use all parts from a carbed engine. Quote Link to comment Share on other sites More sharing options...
mxman70 Posted June 18, 2005 Author Share Posted June 18, 2005 What I have is the 91 engine and wiring in total for mpfi. What would have to be switched? Pat Quote Link to comment Share on other sites More sharing options...
