3 Door Coupe windshield....
17 replies to this topic
#1 WJM
WJM
    SUBARU
  • 7,828 posts
Posted 20 June 2005 - 12:01 AM
so....since we've got 3 RX's in Atlanta...all with damaged WS's....and only one of them is good enough to pass a state inspection...I figure its time to see about getting some....
so what do you guys recommend...? Mine is so bad you CANNOT drive it at all...so, id have to have someone come out to install...got a quote online, and it was $150 for jsut the glass..about $240 for glass+molding (what modling is this?!?!) and it was $306 installed on site....
any of you guys have any recommendations?
#2 GLCraig
GLCraig
    Frak
  • 2,706 posts
  • Canby @#$% Oregon
Posted 20 June 2005 - 02:33 AM
the molding is probably just the plastic trim that goes around the glass
#3 subaru_styles
subaru_styles
    the 1st RX wagon!
  • 1,696 posts
  • OMGhi2U in da couve
Posted 20 June 2005 - 02:51 AM
yeah unless your molding is fubar'd you can reuse it...when i first had the red coupe i got a new windsheild installed for $135.
call around local shops...most places will give you the "insurance" qoutes installed, but keep trying other shops and let them know your paying out of pocket
#4 TahoeFerrari
TahoeFerrari
    USMB Regular
  • PipPipPip
  • 106 posts
  • Tahoe City
Posted 20 June 2005 - 06:45 AM
Check with a few glass shops, prices can vary a lot. I just got my '87 3-door ws replaced for $165 (re-using old molding which is just the plastic trim around the outside) at Low Priced Glass in Sparks, NV. I also had a quote from another place for $290.
I don't know if you have any "Low Priced Glass" shops in GA, but around here they are lower than anyone else.
Also be sure that the shop has the correct ws in stock before they start the job. Glass shops here (including Low Price Glass) tried to tell me that 3-door ws was the same as gl/loyale wagons and sedans. Its not. 3 door / RX ws is different. If I remember right, ws was #530 which I think may be some kind of industry "standard" number for a 3-door ws.
#5 Qman
Qman
    Happiness is... no lag!!
  • Moderator
  • 11,119 posts
  • Sumner
Posted 20 June 2005 - 10:02 AM
Correct, the 3dr has a unique ws. The molding is also different. It has the cupped edges that are supposed to aid in keeping the water from the ws out of the side windows. The other models do not have this type.
#6 JWX
JWX
    Lonely driver
  • 3,073 posts
  • Atlanta
Posted 20 June 2005 - 10:15 AM
theres 4 and only two are damaged. the other is fine. :rolleyes:
#7 WJM
WJM
    SUBARU
  • 7,828 posts
Posted 20 June 2005 - 11:01 AM
the ROT doesnt count AND you siad that you broke the 88's... :-p
#8 NorthWet
NorthWet
    Eeyore Incarnate
  • 5,039 posts
  • Bremerton, WA
Posted 20 June 2005 - 11:20 AM
4 total
- 2 damaged
1 fine
Hmmmmm....
"Math is HARD!" - Talking Barbie
:lol:
#9 NorthWet
NorthWet
    Eeyore Incarnate
  • 5,039 posts
  • Bremerton, WA
Posted 20 June 2005 - 11:23 AM
I just priced a windshield replacement for a wagon, and it was $235 at shop, another $100 if the molding was too deteriorated to be reusable. Thanks for the tip about saying it will be out-of-pocket; I hadn't thought about that.
BTW, I was there to price replacement for an XT rear quarter window. It was $230!!!
#10 JWX
JWX
    Lonely driver
  • 3,073 posts
  • Atlanta
Posted 20 June 2005 - 02:33 PM
I meant 4 RX's total, and of the three winshelds that are damaged. I didn't say broke, just messed up a little.
#11 WJM
WJM
    SUBARU
  • 7,828 posts
Posted 20 June 2005 - 03:50 PM
well, two of them are beyond messed up a little...
#12 Do It Sidewayz
Do It Sidewayz
    Subaru Fanatic!
  • 464 posts
  • Toronto, Ontario
Posted 20 June 2005 - 04:30 PM
order the windshield and install yourself.
Just call around to the glass places in town, and find some of the urethane they use. Someone will be helpful and sell it to you.
I called around to plenty of places when i needed to put the windshield back in the rally car after i did the cage, anyways. everyone wanted like 150 bucks to just install a windshield...i had the windshield sitting beside the car, all they needed to do was lay a bead of the urethane and then plop the windshield in.
Long story short....i found someone who sold me 2 tubes of the urethane, and some of the little rubbers to space the windshield up from the bottom. All cost me $40 cdn. They were also very helpful by telling me how to cut the urethane tube for best application, and exactly how to do things.
After doing it...it's very DIY.
#13 WJM
WJM
    SUBARU
  • 7,828 posts
Posted 20 June 2005 - 04:44 PM
ok....so....how do i properly remove a busted one (thats still very intact...just all cracked up in like 1090759872563409 places) and prep it for a new one....? and all those other tihngs you learned...?
#14 DrKrazy
DrKrazy
    Which one to drive today?
  • 935 posts
  • Golden
Posted 20 June 2005 - 06:55 PM
Also listening closely...since I need to pull my broken one and fix some rust on the pillars before I can install (or have someone install) a new one.
Good thread..
#15 scrapdaddytatum
scrapdaddytatum
    the subaru surgeon
  • 790 posts
  • charlottesville, virginia
Posted 20 June 2005 - 07:08 PM
a couple of notes for you nuts
3door coupes have a longer windshield, about 3 inches
rx is same as 3doors
piano wire and 2 screw drivers, 2 people and 20 minutes
windshield out, if i need to explain what to do with the wire
your screwed anyway and should have it installed for you
go buy some urethane caulk, napa sells it, or buy the urethane cord,
autozone/advance auto, REALLY, REALLY, REALLY CLEAN THE GUTTER
WHERE THE OLD SEAL WAS, WIPE WITH ALCOHOL, SAND AWAY RUST,
PRIME IT, DO WHAT EVER YOU HAVE TO, TO MAKE A SMOOTH CLEAN SURFACE
FOR THE NEW GASKET, put the new seal in the cleaned up gutter
install new glass, or junkyard glass, if junkyard clean the hell out of it too,
and be nice and easy, press from the center of the glass, both people, and kind of jiggle it, this sets the seal, dont press near edges, it will crack, put some masking tape top and bottom, leave a window cracked, sont slam a door for 2 days,
i have swaped dozens of WS, and have never had a problem
#16 WJM
WJM
    SUBARU
  • 7,828 posts
Posted 20 June 2005 - 11:49 PM
what is piano wire?
:-p
#17 JWX
JWX
    Lonely driver
  • 3,073 posts
  • Atlanta
Posted 21 June 2005 - 01:13 AM
I say we try it, not a lot to lose.
#18 scrapdaddytatum
scrapdaddytatum
    the subaru surgeon
  • 790 posts
Posted 21 June 2005 - 06:35 AM
um it comes out of a piano, u can also use quitar string
