What do Used Webers go for???
5 replies to this topic
#1 vodoobrat
vodoobrat
    USMB Regular
  • PipPipPip
  • 61 posts
  • Meridian,Idaho
Posted 11 September 2003 - 05:03 PM
I have this Weber Carb I pulled off a 85 GL 4X4 and was wondering what the normally go for. It looks like it is in good shape. I was going to us it for my brat but wasn't sure if it would work. The 85 I pulled it off of was an OHC engine and my 83 brat is a pushrod.
Any info would be great
Vo
#2 Superoo
Superoo
    New User
  • PipPip
  • 10 posts
  • Winnemucca, NV
Posted 11 September 2003 - 05:22 PM
It won't work at all. I'll give you 20 dolla.
Actually if you get the adapter (about $35 I think) it should work fine as is on your EA81.
My Weber kit (87 GL) from piercemanifold.com was around $330. That included the carb to manifold adapter, gaskets, etc.
On my 87 w/ AC there were some clearance issues with the compressor but nothing serious.
#3 Flowmastered87GL
Flowmastered87GL
    WCSS Drunk
  • 6,256 posts
  • Portland, Oregon
Posted 11 September 2003 - 07:11 PM
Used webers go from $30 up usually. If they dont need a rebuild and are already set up for a subaru they are wortha bit more. If they are off an unknown vehicle and need a rebuild and rejetting, no more than $50 in my opinion. Sounds as is yours is in decent shape. I would hold onto it and stick it on the EA81 though.
#4 edrach
edrach
    RIP 6/28/14
  • 12,326 posts
  • Bothell, WA
Posted 11 September 2003 - 09:01 PM
Is it a two barrel weber? The single barrel Carter-weber is not worth a lot. If it came off a '85 GL make sure you get the adapter plate and throttle linkage pieces. The dual barrel weber with fit on either the EA81 or EA82 manifolds.
#5 vodoobrat
vodoobrat
    USMB Regular
  • PipPipPip
  • 61 posts
  • Meridian,Idaho
Posted 11 September 2003 - 09:12 PM
It does look like it is in pretty good shape and I did get the adaptor plate and throttle linkage. So i think I am all set. I will take a picture of it this weekend and show it to you guys and you can give me some more infor
#6 Tom63050
Tom63050
    Subaru Fanatic!
  • 373 posts
  • St. Louis
Posted 11 September 2003 - 11:22 PM
The adaptor for the EA82 OHC motor's intake manifold is different from the adaptor for the EA81 pushrod motor's manifold. You can put the EA82 manifold on the EA81, but it would be easier to just go buy the EA81 manifold.
