sam45 Posted June 22, 2005 Share Posted June 22, 2005 My 1996 Legacy 2.2L Wagon (Auto) has lately developed a problem with starting. When I turn the key it clicks. When I turn it on and off rapidly, it starts. It is getting worse by the day. The battery appears to be OK. I am suspecting the starter and would like to replace it myself with an aftermarket one to save a few dollars. Is it something that can be done without raising the car or getting underneath? Can anyone point to the instructions as the haynes I have makes it sound as not so simple? Are there any aftermarket ones that are good and not expensive? I appreciate any help that you can provide. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
lmdew Posted June 22, 2005 Share Posted June 22, 2005 Do a search here, this was talked about a few months ago. Easy Job, no reason to go under the car. 1 bolt on top, 14mm. 1 nut on the bottom 17mm and the two wires. Make sure you disconnect the battery before you start. If you want a cheap used starter, I have a couple good ones $5 +shipping. Quote Link to comment Share on other sites More sharing options...
blackbart Posted June 23, 2005 Share Posted June 23, 2005 My 94 did the same thing last week, the ground terminal on the battery was ugly, I cleaned it up and the problem was gone. I had a spare starter in my hand, ready to swap it in, then I checked the connections on the battery and the starter. The battery terminal looked ok from the outside but there was alot of corosion once I pulled the connecter off. Quote Link to comment Share on other sites More sharing options...
Olnick Posted June 23, 2005 Share Posted June 23, 2005 Betcha' it's nothing more than worn contacts inside the starter. It's a common problem. Just a coupla' bucks to replace--compare that to the cost of a new or rebuilt unit! Not too hard to do either. Search here on the board as lmdew suggests. And by all means do what blackbart says and check/clean all your electrical connections. Quote Link to comment Share on other sites More sharing options...
sam45 Posted June 25, 2005 Author Share Posted June 25, 2005 The current starter is 9 years old so thought might as well replace. I got a good deal on a reman starter from the dealer. Tried to fix it, but the car too hot. Was in a rush. Took it to the corner gas station guy who charged just 50 for labor! The car starts fine now. It worked out well. Thanks everyone for your suggestions!! Quote Link to comment Share on other sites More sharing options...
