2wd to 4wd ???
4 replies to this topic
#1 1he1m8
1he1m8
    New User
  • Pip
  • 3 posts
  • Haifa
Posted 25 June 2005 - 12:39 PM
Hi,
I'm living outside the state and in my country i have 93' brat.... they continue produse it till 94'-95'....
So, My question is : can i change 2wd to 4wd ??? what is the necessary parts ? does someone know a kit for it ?
thanks a lot...
#2 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
  • Madison/Milwaukee, WI
Posted 25 June 2005 - 02:10 PM
4wd will bolt right in. as long as you have all the parts.
i wonderif the rear suspension tube will have4 the mount for a diff?
in the states brats came as 4wd only and only one year for an automatic, up until 87
is yours fwd 5spd or automatic?
#3 1he1m8
1he1m8
    New User
  • Pip
  • 3 posts
  • Haifa
Posted 26 June 2005 - 10:53 AM
Thanks for ans.....
i have 5spd.
and do you know what are all the parts ? and where can i get them ?
do you know someone who did it ? what about kit ?
#4 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
Posted 26 June 2005 - 01:33 PM
i have done the conversion myself to a wagon
along with the tranny you will need the flywheel and clutch that goes to it, along with the 2 piece driveshaft. you willeither have to fabricate a mount for the 2 piece driveshaft or shorten a driveshaft from a 4spd model
if your car is a 2wd 5spd your existing tranny crossmember will work. if its an automatic, you need to find a crossmember from another brat or wagon or hatchback of that body style(4 headlights)
you will need the entire rear suspension assembly from a 4wd brat, wagon, or hatch of the same body. or you can fabricate a mount for the diff on your existing suspension, and swap in 4wd trailing arms. you will also need a differential and crossmember with a 3.9 final gear ratio, the ratio will be on a tag on the back of the diff
its more economical to grab the entire rear suspension, diff and all of a donor vehicle
your existing clutch cable will work
you may have to beat the tranny tunnel in a little but, or put spacers on the crossmember mounts to drop the tranny down a half inch or so to clear, as its a tight fit
you may also have to trim the shifter hole up a little to make toom for 5th and reverse.
#5 1he1m8
1he1m8
    New User
  • Pip
  • 3 posts
  • Haifa
Posted 27 June 2005 - 08:20 AM
Thanks alot !!!
I looked at your wagon and it looks very cool !!!
i'll update the furom if after i'll try this convertaion....
