Help: Turn signals, hazard flashers and horn dont work
9 replies to this topic
#1 Subsforever
Subsforever
    USMB Regular
  • PipPipPip
  • 57 posts
  • Covington
Posted 26 June 2005 - 11:06 PM
I just finished putting a new engine in my 1982 4wd wagon, everything works but the Turn signals, Hazard flashers, and horn. I checked the fuses and they are fine but their is now power where the fuses plug in, any suggestions as to where to look for the problem.
#2 Cougar
Cougar
    Elite Master of the Subaru
  • 6,563 posts
  • Anchorage
Posted 26 June 2005 - 11:24 PM
Check the fusible links next.
#3 Subsforever
Subsforever
    USMB Regular
  • PipPipPip
  • 57 posts
  • Covington
Posted 26 June 2005 - 11:48 PM
Thanks just did and their fine
actually i just looked at the fuses agian they have power but the two flasher relays dont have any power
#4 Cougar
Cougar
  • 6,563 posts
  • Anchorage
Posted 27 June 2005 - 05:43 AM
You don't state how you are checking the power. Did the power to the fuses suddenly start to work or was there a problem in the testing? If the fuses have power now but the flashers don't then you need to trace back the supply wire as I guess you know.
#5 Sweet82
Sweet82
  • 3,274 posts
  • Salt Lake City
Posted 27 June 2005 - 09:50 AM
When I transplanted the wiring harness and motor to the buggy, I had the same issue.
My problem was a toasted flasher unit and rusty horn wires. They worked before I messed with them but not after.
You need to trace the power to those units???
Good Luck,
Glenn
82 SubaruHummer
01 Forester
#6 Sweet82
Sweet82
  • 3,274 posts
  • Salt Lake City
Posted 27 June 2005 - 09:52 AM
Side note....
Way too many Glenn's answering this post...
#7 Cougar
Cougar
  • 6,563 posts
  • Anchorage
Posted 27 June 2005 - 05:06 PM
Yeah, this is strange.
#8 mcbrat
mcbrat
    Brattitude Adjustment
  • Administrator
  • 11,185 posts
  • Central Iowa
Posted 27 June 2005 - 08:22 PM
ha. when I saw the title, I thought to myself... I bet it's an '82 :lol:
I ended up adding new wiring to my circuits, instead of properly chasing down the culprit....
the '82s seem to be prone to wiring issues.....
#9 Subsforever
Subsforever
    USMB Regular
  • PipPipPip
  • 57 posts
  • Covington
Posted 27 July 2005 - 03:23 AM
Fixed the problem turns out that when i changed engines the ac compesor being unbolted caused the splice from the fuse box to the horn and emergency flashers to come loose the splice was done with only electrical tape for some reason, respliced it with a wire nut problem solved. turns out the blinkers worked all along they just where not working when i tested them becuase the hazard switch was still pushed in which disables them.
#10 Cougar
Cougar
  • 6,563 posts
  • Anchorage
Posted 27 July 2005 - 09:48 AM
Good show. Glad you got it fixed and thanks for the update.
