reoff Posted September 13, 2003 Share Posted September 13, 2003 Now that I got the A/C switch installed... I'm working on the override switch for the aux fan. Anyone know what the "best" way to do this is? I have a 20amp switch, so I'll probably just run a separate power wire to it through the main fuse. Let me know if you know the better way(i know there is a better way... just don't remember what it is). Also... which wires do i need to short for the A/C fan problem(not coming on w/ the a/c)? Thanks, Rich Quote Link to comment Share on other sites More sharing options...
DoughtCom Posted September 13, 2003 Share Posted September 13, 2003 I know MorganM has a relay setup for his DC Radiator fan installed. With a low amperage switch used. That would a be a good way to do it as well. I personally, with my limited experience, don't see why a switch wouldn't be a good way. If you have a switch that handles 20 amps, that should be adequate enough to power the fan. Quote Link to comment Share on other sites More sharing options...
reoff Posted September 13, 2003 Author Share Posted September 13, 2003 That was actually pretty easy once I remembered that all I needed was to ground the fan to get it on. All works well, and on the the next project. Rich Quote Link to comment Share on other sites More sharing options...
