Remove Pinion from R160 Diff
2 replies to this topic
#1 d1camero
d1camero
    New User
  • Pip
  • 4 posts
  • canuckland
Posted 04 July 2005 - 07:30 AM
I have an r160 from a 1995 Impreza. I am just bead blasting it, and want to remove the pinion before getting it full of grit. How to the pinion come out? The pinion nut is off.
thanks
d1
#2 blackbart
blackbart
    tlegacy driver
  • 449 posts
  • Northeast PA
Posted 04 July 2005 - 07:41 AM
thanks
d1
You have to press it out, of course you have to remove the ring carrier first.
I wouldn't do this just to clean it up, can't you tape off the nut area instead?
When you go to put things back together you will have to check for backlash, the spacing between the teeth on the ring and pinion. This is done with shimms. (Don't take it apart.)
#3 NorthWet
NorthWet
    Eeyore Incarnate
  • 5,039 posts
  • Bremerton, WA
Posted 04 July 2005 - 11:52 AM
Messing with the pinion can put you in a world of hurt. Listen to what blackbart said. It is not worth it. Much better to mask of the areas that you are concerned about.
