1997 Subaru Outback , Starter Replcement
5 replies to this topic
#1 peryea
peryea
    New User
  • Pip
  • 1 posts
  • lINCOLN vERMONT
Posted 05 July 2005 - 07:46 AM
I think the starter on my `1997 outback needs to be replaced. Does anyone know HOW ???? Is it hard to do ???? Thanks !! peryea
#2 75subie
75subie
    I`m sold on Subaru
  • 3,911 posts
  • Walden
Posted 05 July 2005 - 09:09 AM
you need to go to the newer generation forum.this forum is for cars 1980 and older
#3 grossgary
grossgary
    Elite Master of the Subaru
  • 22,740 posts
  • East Coast
Posted 05 July 2005 - 06:09 PM
starter shouldn't be going out this soon. are you sure your battery cables are on the battery posts tight? any corrosion around the battery terminals? try to jump the car with cables, if that works fine then the starter is fine. if you're stuck, knock the starter a couple times with a hammer and it'll keep working (that's not a joke). i did that to mine in january (on my 89 XT6) and it's been working fine since....which reminds me i meant to replace that when it got warmer. thanks for reminding me.
it's really easy. i saw my 97 outback starter while changing the plugs the other day, looked straight forward to replace. probably 2 bolts and the electrical connections to get it out. it's a little tight back there but looks fine. go at it, it's only two bolts!
#4 lmdew
lmdew
    _______
  • 3,594 posts
  • Colorado Springs
Posted 05 July 2005 - 08:27 PM
Not hard, the bottom nut can be a pain sometimes. Otherwise disconnect the battery, pull the positive lead and switch wire off the starter. Pull the bottom nut 17mm, pull the top bolt 14mm. Put it all back the other way.
#5 Olnick
Olnick
    Ol' Subaru Guy
  • 3,005 posts
  • Honolulu HI
Posted 05 July 2005 - 11:13 PM
Another suggestion--use the search function. Topic has been discussed a lot in the past year.
#6 Andyjo
Andyjo
    I'm Not Austin!
  • 1,808 posts
  • Windham NH
Posted 05 July 2005 - 11:18 PM
I think i have a similar problem, whenever it's sort of cold out, i turn on the car, and right after the motor catches and fires up there's a scraching noise. I'm guessing it's the spring that disengages the starter... any thoughts?
