mtbshark Posted July 8, 2005 Share Posted July 8, 2005 i am going to change my ATF fluid and am wondering what brand perfoms the best. RED LINE Royal Purple Ams Oil tried any??? Quote Link to comment Share on other sites More sharing options...
subie94 Posted July 9, 2005 Share Posted July 9, 2005 though i have a 5spd,i have heard good things about royal purple.seeing that atf is used for power steering,maybe i'll try it out to see what effects i get Quote Link to comment Share on other sites More sharing options...
MiniTransAm Posted July 9, 2005 Share Posted July 9, 2005 I have always had excellent luck with Mobil and Mobil1 products. I'm extremly loyal I guess you would say when it comes to the fluids in my car. Always mobil fluids, Sunoco (or Mobil) gas, and chevron fuel system cleaner. If you want extremely good protection, I'd get the Mobil 1 ATF. about $5 bucks a quart. Quote Link to comment Share on other sites More sharing options...
Legacy777 Posted July 9, 2005 Share Posted July 9, 2005 Redline D4 ATF is good stuff. Quote Link to comment Share on other sites More sharing options...
dklein90 Posted July 9, 2005 Share Posted July 9, 2005 How are you going to put that good stuff into the trans. Id like to put in some higher quality fluids but I would hate to mix it with the old burnt up fluid. atf fluid change check out this forum for more info. Quote Link to comment Share on other sites More sharing options...
MiniTransAm Posted July 9, 2005 Share Posted July 9, 2005 Eh, if you keep doing flush and fills, like 3 or so, you'd pretty much have new good fluid in there. You could also do a flush and fill and that would have new fluid. I put it in because we just bought the car used and the tranny fluid was never changed it looks like. So since I new I'd be doing at least 2 drain and fills and I had to fix a tranny pan leak, I new I'd get alot of the old stuff out. Quote Link to comment Share on other sites More sharing options...
Subie Gal Posted July 9, 2005 Share Posted July 9, 2005 Redline ATF has worked for me I currently use it as my power steering fluid on the race car Jamie Quote Link to comment Share on other sites More sharing options...
Olnick Posted July 9, 2005 Share Posted July 9, 2005 MiniTransAm--by "flush-and-fill" do you mean to disconnect the ATF return line from the radiator and put it in a container of fresh fluid, putting a "disposal" tube from the radiator's output and feeding it into a clear container, then running the engine until the fresh, clean fluid starts to come through? Never tried it since my Legacy is 5spd, but remember reading about it on some other board awhile back. Does this system work on a Subaru? Seems like a good idea--especially if your swapping to a high quality, more expensive fluid. Quote Link to comment Share on other sites More sharing options...
