bgambino Posted July 10, 2005 Share Posted July 10, 2005 I need to take some of the front end off my nieces 96 legacy 4 door sedan and probably make a few cuts in the metal and do a little banging (with a sledge) and some pulling with a come-along---she had an accident and scewed the drivers light among other things Can the air bags be deactivated so I don't accidently deploy them?? thanks bill Quote Link to comment Share on other sites More sharing options...
bgambino Posted July 11, 2005 Author Share Posted July 11, 2005 help....anyone have an idea?? I need to take some of the front end off my nieces 96 legacy 4 door sedan and probably make a few cuts in the metal and do a little banging (with a sledge) and some pulling with a come-along---she had an accident and scewed the drivers light among other things Can the air bags be deactivated so I don't accidently deploy them?? thanks bill Quote Link to comment Share on other sites More sharing options...
Spazz698 Posted July 11, 2005 Share Posted July 11, 2005 According to the legacy manual you have to do the following: 1) point wheels forward 2) disconnect neg. battery terminal 3) wait at least one minute so the backup power supply can be depleted. that's pretty much it, after that it goes on about what to do if you remove a live airbag...from my training I know you can also hunt down the yellow connectors (they say airbag or SRS all over them) and unplug it. Can do the same if you can find the sensors (you dont need to unplug everything, the manual says you dont have to unplug anything but I was trained to disarm them and unplug the connector going into the steering column for safety) BTW, if you unplug stuff, do it after you do the first 3 steps. Quote Link to comment Share on other sites More sharing options...
bgambino Posted July 12, 2005 Author Share Posted July 12, 2005 thanks spazz According to the legacy manual you have to do the following:1) point wheels forward 2) disconnect neg. battery terminal 3) wait at least one minute so the backup power supply can be depleted. that's pretty much it, after that it goes on about what to do if you remove a live airbag...from my training I know you can also hunt down the yellow connectors (they say airbag or SRS all over them) and unplug it. Can do the same if you can find the sensors (you dont need to unplug everything, the manual says you dont have to unplug anything but I was trained to disarm them and unplug the connector going into the steering column for safety) BTW, if you unplug stuff, do it after you do the first 3 steps. Quote Link to comment Share on other sites More sharing options...
