subeseller Posted July 12, 2005 Share Posted July 12, 2005 AM I doomed? Just got a 2.5 Impreza, has a little bit wobbly crank pulley/dampner. Tried to tighten but didn't get one micron of a turn. Any luck changing the pulley or...is the crank end bent and I"m doomed? Take off and retighten? Any help I'm very grateful for. dh. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted July 12, 2005 Share Posted July 12, 2005 tightening or reinstalling probably won't work. you need to replace the pulley or the crank is toast. i think it highly unlikely the crank is toast. but a bad pulley can ruin your crank, so best to fix this immediately. not sure why it's wobbling, be nice to know. it's likely not a big deal now, but if you let it go too long it could definitely seriously damage your crank and that's a pain in the rump roast to deal with if you don't know what you're doing. (it can be done but you better have good machinists around). if it's a harmonic damper type crank pulley then a new pulley will likely be in order. personally i'd get an aluminum solid piece crank pulley and replace the stock one if it's a harmonic balancer type (which i think it is, i know the 2.2's are). all subaru crank pulley's i've seen are harmonic balancers but i've never seen a 2.5 liter motor. have the pulley checked and start sourcing another one. Quote Link to comment Share on other sites More sharing options...
swi66 Posted July 13, 2005 Share Posted July 13, 2005 Happened to me on my 98 Legacy with 90,000 miles. It was so bad the crank was toast. For me I had the motor changed, rather than change a crank. Very expensive! swi66 Quote Link to comment Share on other sites More sharing options...
Sweet82 Posted July 13, 2005 Share Posted July 13, 2005 I understand that on some models of the Impreza, the factory torque specks for the pulley's are misprinted. Aparently they require MUCH more than the manual specifys. It is actually a fairly common problem, more people than you'd think have WELDED the pulleys back on. My neighbor welded his pulley on his Impreza and the car works fine. I understand from engine rebuilding places that they see this frequently on the Impreza. Good Luck, Glenn 82 SubaruHummer 01 Forester Quote Link to comment Share on other sites More sharing options...
