I know this has been discussed, would some one line me up with a link or give me the basics, what clutch,axles and drive shaft is needed. I know i need the pedal assembly, and other obvious things. The kid took out the tranny last night on her t-coupe. oh yea, will this affect in any way the digi dash? strange ? just curios.
Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
3at 4wd T-coupe To 4 Or 5 Spd?
Started by
LUVMYBRAT
, Jul 19 2005 08:56 AM
5 replies to this topic
#1
Posted 19 July 2005 - 08:56 AM
#2
Posted 19 July 2005 - 09:24 AM
The biggest difference I can see is...
The 4 speed tranny has a one piece driveline
The 5 speed has a two piece driveline which means more work.
Along with the pedal box you'll need the cable for the clutch...
Good Luck,
Glenn
Good Luck,
Glenn
#3
Posted 19 July 2005 - 09:39 AM
EA81 or EA82?
#4
Posted 19 July 2005 - 09:43 AM
84 EA81 turbo coupe 4wd 3at
#5
Posted 19 July 2005 - 12:57 PM
well Bill, a custom driveshaft would have to be made for the EA82 5-speed tranny whereas just an EA81 manual tranny driveshaft would work. Axles would be the same from an EA81 manual and EA81 auto but the EA82 turbo trannys have the bigger splines on the DOJ side. There's a good set of axles in the parts car and tranny ('85 GL-10 turbosedan) and the gearing is the same as the turbocoupe so no changing the rear ends out. I would recommend an EA82 clutch setup for it since it'll be able to hold the power a little more then the EA81 clutch.
#6
Posted 19 July 2005 - 06:11 PM
The 4spd sucks bad on a turbo, been there - done that. I went through 3 clutches in barely 3 months.
Carfreak should speak up, he's done the 5spd swap on his turbo wagon. The only issue is the driveshaft I believe.
