Getting new stereo, have questions?
13 replies to this topic
#1 soobmater
soobmater
    Got Mud?
  • 1,668 posts
  • South Bend
Posted 19 July 2005 - 11:16 PM
well i am thinking of getting a stereo. i want to run 2 6x9's and a small sub.(probably a 8") is there anything i should be aware of? i plan not to run a amp. and those adapter plates, where do you get them at???
thanks in advance for any help.:)
o and by the way, it is in my 85 wagon
#2 Mykeys Toy
Mykeys Toy
    Subaru Master
  • 2,087 posts
  • South Prairie, Wa
Posted 19 July 2005 - 11:24 PM
Yup.. suggestion
Run seperate wire from the deck to the 6x9s and get a amp for the sub or you wont even hear it.. Make sure the amp has a built in crossover and set it to low pass at around 60-70 hz or you will get into the midbass range and that will sound funny with your 6x9s.
Mike
#3 soobmater
soobmater
    Got Mud?
  • 1,668 posts
  • South Bend
Posted 19 July 2005 - 11:30 PM
Yup.. suggestion
Mike
ok thanks, thats some very helpful info, dont know to much about stereo systems. i should get it sometime next month. how bout those adapter plates?
#4 Mykeys Toy
Mykeys Toy
    Subaru Master
  • 2,087 posts
  • South Prairie, Wa
Posted 19 July 2005 - 11:33 PM
I dont have a wagon so I have no idea what they look like or where to get them. Personally I think a decentset of 5 1/4 or 6 1/2 coaxial speakers would sound better and be easier to install and you may not have to use adapter plates.
#5 soobmater
soobmater
    Got Mud?
  • 1,668 posts
  • South Bend
Posted 19 July 2005 - 11:42 PM
duo! i should have been more specific. i need the adapter plate for the deck. im gona put the 6x9's in boxes in the back.
#6 freeldr
freeldr
    USMB Regular
  • PipPipPip
  • 98 posts
  • Kent,wa
Posted 19 July 2005 - 11:54 PM
suggestion.........
keep the the 6.5" in the rear doors lose the 6x9's and the adapter plate you can get at any car audio shop. im putting my system im my 85 wagon right now. if ya need any help let me know i may be able to come help you
#7 Mykeys Toy
Mykeys Toy
    Subaru Master
  • 2,087 posts
  • South Prairie, Wa
Posted 20 July 2005 - 12:06 AM
I see. some shops may have to order the plate but no biggy.
#8 soobmater
soobmater
    Got Mud?
  • 1,668 posts
  • South Bend
Posted 20 July 2005 - 12:07 AM
well i kinda wanted to put some 6x9's in the back behind the seat. thanks for your sugestion though.
#9 boof
boof
    New User
  • PipPip
  • 13 posts
  • sydney
Posted 20 July 2005 - 02:19 AM
why 6x9's and a 8" sub?
Either a good set of spilts with the 8"
or
the 6x9's with a bigger sub will sound alot better.
Ohh and you will need a amp.:headbang:
#10 soobmater
soobmater
    Got Mud?
  • 1,668 posts
  • South Bend
Posted 20 July 2005 - 12:32 PM
well honestly i wanted a 10" sub but i didnt want to run a amp. i dont know if i have to run a amp i might as well go with a 12" sub. are amps a pia to hook up? i will most likely not have enough money for all of this at once so i think i will just hook up the 6x9's and then when i have enough money, get a sub and a amp. and 1 more question, whats a good not to expensive sub?
#11 soobmater
soobmater
    Got Mud?
  • 1,668 posts
  • South Bend
Posted 20 July 2005 - 03:21 PM
and the deck, is there enough room for one. Length-is there enough space???? the deck i want is 7inches deep. how much do gl wagons have?
#12 Mykeys Toy
Mykeys Toy
    Subaru Master
  • 2,087 posts
  • South Prairie, Wa
Posted 20 July 2005 - 05:54 PM
I will answer the deck Q first.. The adapter plate will also be a spacer so depth should not be an issue.
And as for amp sub etc.. those in the end are all personal preference.. If you want I can post up some places online (not ebay) that I trust and use fairly regularly.. Or I have an MTX roadthunder 10 in a box that I used for about a month and a lightening audio 4 channel amp that I have no need for ( used for about 2 months).. The amp will run your 6x9s or front speakers and the sub if you want them.. PM me if you want to know more.
Mike
#13 soobmater
soobmater
    Got Mud?
  • 1,668 posts
  • South Bend
Posted 21 July 2005 - 03:12 PM
i pmed you. is there any more sugestions?
#14 ausubaru92
ausubaru92
    Turbo Talker
  • 583 posts
  • Bowraville NSW Australia
Posted 22 July 2005 - 06:47 AM
A amp will prob need its own supply from the battery (depends on the power level = current draw)
I put my 6x9's in boxes behind the drivers seat and it makes my bum vibrate with the bass :D
Im gonna add a sub with an amp soon too but need much required $$$$
Gannon
