I've been advised by a couple of people now in email that "popping out of first gear" could be due to wear on the "shifter bushings" or a "bent linkage" -- and not a transmission problem, after my four attempts at a replacement tranny.
But I don't understand -- I thought the the "shifter bushings" and "linkage" stay on the car side and stay in place?
Do they get changed each time the mechanic tries another transmission?
Original tranny, 230,000 plus miles -- popping out of first and third gear, both 2wd and 4wd, mostly while coasting to a stop, engine braking.
First replacement -- did NOT pop out, went 300 miles. Threw engine codes, lacked one wire hookup, taken out.
Second replacement -- did NOT pop out of gear, went 300 miles, had the wrong ratio for rear end, wore out tires, hung up in 4wd and lurched badly when finally forced back to 2wd. Taken out.
Third replacement -- first replacement, finally, that actually matches the transmission model number on the tag from my original transmission -- same one I got on another USMB thread. Does not throw any codes and shifts smoothly. DOES pop out of first gear, after the first 30 miles of driving, in 2wd, while decelerating. Same as my first tranny (which I still have, in the back of the Subaru -- thinking I may yet send it to CCCR for rebuild!)
All the replacements so far are "Used Japanese" -- and I figured the current one is finally the exact right part number, but is worn out like my own was.
---> Is there any way that worn shifter bushings would
a) not have been caught by the mechanic, if he's been awake?
c) NOT cause problems on two transmissions then cause trouble again on the third one?
I am in over my head here. I thought I"d eliminated this as a possible cause and am still confused.
If it weren't for the carpal tunnel, I'd go back to bicycling, but that beats my wrists up. Maybe a unicycle .... or a recumbent. Or just a deck chair.
