angry at weber
12 replies to this topic
#1 archemitis
archemitis
    guy smiley
  • 3,554 posts
  • the big minnie
Posted 16 September 2003 - 10:30 AM
i have been runing a weber on my ea82 carb motor for about 6months now, and i have never got it to run right. it seems like it needs double accelerator pumps, because when i mash the throttle theres nothing, then all the sudden she goes like crazy. which makes me think i need more fuel from the accelerator pump, does that sound right? im about to go back to a hitachi, because im not sure this 32/36 is all its cracked up to be.
in short i need some help with jetting and tuning.
#2 mcbrat
mcbrat
    Brattitude Adjustment
  • Administrator
  • 11,185 posts
  • Central Iowa
Posted 16 September 2003 - 10:37 AM
mine was the same way, and I ended up increasing the timing....
#3 archemitis
archemitis
    guy smiley
  • 3,554 posts
  • the big minnie
Posted 16 September 2003 - 10:56 AM
i have been trying to get the carb right with the stock timing... never thought it could be a timing issue.hrmm
#4 Qman
Qman
    Happiness is... no lag!!
  • Moderator
  • 11,119 posts
  • Sumner
Posted 16 September 2003 - 02:47 PM
Advance the timing to 10-12 degrees. Then after you adjust the idle adjust the idle mixture. Turn it in until the engine starts to run rough but doesn't die. Then adjust it out until it smooths out then turn it out another 1-1 1/2 turns and it should be set. Also make sure you have zero vacuum leaks. That will affect the performance more than anything.
#5 GLCraig
GLCraig
    Frak
  • 2,706 posts
  • Canby @#$% Oregon
Posted 16 September 2003 - 03:45 PM
It sounds like you have too big of a secondary jet and what's happening is you're giving it too much fuel.
#6 GeneralDisorder
GeneralDisorder
    Elite Master of the Subaru
  • 21,704 posts
  • Portland
Posted 16 September 2003 - 04:46 PM
Yeah - I've had to adjust the timing as well, but I still have the same problem you describe - when I give it WOT, it tries to die, and then takes off. Also - when I take sharp left hand turns, the engine dies completely. My weber came from the weber official kit, so I don't know why it should act this way. Thinking I may have to adjust the float level, and I am going to check the fuel pump pressure as well - it sure doesn't seem very high to me.
#7 Svengouli7
Svengouli7
    Smile, taste kittens
  • 320 posts
  • Bentucky Wa.
Posted 16 September 2003 - 09:50 PM
I had increased jet sizes trying to hunt down similar problems.. had put in a larger jets... seemed to give a bit more power overall, turned out I was getting about 16-18 mpg!
I am diggin to find what sizes I have in right now... still not as snappy between primary and secondary as it should be I'd guess.
I also suffered from stalls on hard turns- whatI have read is that webers really ought to be placed with the float pin parallel to the firewall to prevent this temprary starvation. This just doesn't seem an option on our intakes due to the way the barrels are arranged- unless we go dual 32/36'ers but then htere's the linkage.....(?)
I also picked up that low initial power can be attributed to not having a big enough idle jet set up... have not messed w/ that
#8 archemitis
archemitis
    guy smiley
  • 3,554 posts
  • the big minnie
Posted 16 September 2003 - 11:34 PM
you think its too much fuel gtcraig?
#9 mudrat79
mudrat79
    Banned
  • Banned
  • 697 posts
  • Eugene,
Posted 17 September 2003 - 10:40 AM
Pul the Vacuum off the Disty, and Using a long piece of vacuum line test it ( the Disty Vacuum advance) at the Disty...
Do this with engine running at idleand Manually pull air off the vacuum advance, it should idle higher and stay there till you back off the vacuum...
If it pulls then drops on its own, or dosn't pull at all, vacuum advance is bad , which will cause bad hesitation at bottom end.... Very common on stock disty's
Old stock Hitachi carb doesn't pull near as hard as Weber, so it becomes more pronounced....:cornfuzz:
Hope this Helps, John in Oregon.....
#10 archemitis
archemitis
    guy smiley
  • 3,554 posts
  • the big minnie
Posted 17 September 2003 - 04:06 PM
if i suck on the vaccum line coming off the distributor only, i should be able to get the rotor to move right?
and should it bleed down and move withh vacuum still on it, or shoold it stay in the same place as long as vacuum is there
#11 mcbrat
mcbrat
  • Administrator
  • 11,185 posts
  • Central Iowa
Posted 28 September 2003 - 07:30 PM
Good call there by mudrat! I did a little testing today on my 82 wagon, and the vac advance was bad. wouldn't hold the vacuum. I tested on some other spare distys, and it held fine. I swapped out the disty, and seems to respond better. tomorrow will tell when I take it out on the road....
#12 archemitis
archemitis
    guy smiley
  • 3,554 posts
  • the big minnie
Posted 28 September 2003 - 07:48 PM
i was screwing with mine today, and i checked my advance, and it will hold vaccum. and it is still hesitating horribly. it even backfires out the carb, with a fireball, when i pull the throttle wide open, and let off it.
im gonna grab a lite and check that my timing is spot on.
#13 subynut
subynut
    EJ Powa!
  • 1,422 posts
  • Sierra Vista, AZ
Posted 28 September 2003 - 11:14 PM
I've been having similar troubles here too. It would ping real bad then try to stall when I would initally give it gas. I backed the timing off to 6 deg btdc and that helped quite a bit. That hesitaiton is practicly gone and hardly pings any more. Also don't diesel when I turn the key off either.
Ted
