trouble code 32/procedure for O2 replacement??
I would like to replace the O2 sensor in my 91 loyale 4wd non turbo wagon
Whats the procedure to get it out without ripping the threads up?
should I but the special socket or will a box wrench work well enough?
should I put anti seize on the new one?
thanks
I'm getting a 3-2 light pulse....car seems to run okay,,,,maybe a tiny bit rough...anyone know?
I've had more lights come on this sub than all others I've owned since 11/1979
thanks
Bill
will gas mileage suffer?
do you need a special wrench?
What kind of cost do you think?
thanks
Yes, probably... that is if you mean if you don't replace it.
22mm wrench; or there is also a special socket that has a cutout for the wire to slip through.
$25-35
Edit - Oh, and don't just go yanking it out. They tend to stick in their bungs, and then the threads just rip off and you have to run a thread chaser though its... well, its bunghole. Follow removal procedure in manual. end edit
$25-35
^-- what he said :D
I bought the stupid special socket.... used it a grand total of twice now. :rolleyes:
