Does anyone know how to get the release handle trim cover off. It's the part on the left hand side of the dirvers seat on the floor. I already took out the two screws. I cant figure out how to get the lever for the door to the gas cap off. Is it just a push pin or a set srew (like allenwrench or phillips).
On my car, you just pull the plastic pieces off the metal levers.
Ummm... the plastic pieces on mine have a pin or a screw holding the knob/tab on there i think. I dont wanna breakem by yanking on em:-\
Ok got it all fixed. The reason I was doing this was to replace the broken trunk release knob. Turns out you have to pull the levers/knobs straight off, not up and off like I did to my door to the gas tank knob but i think that will be fine just a little bit of a wiggle. As for the broken trunk release knob it was glued or cocked on there by the previous owners, so I had to take a dermal to the part that over hung the cover and then chiseled the rest off with a screw driver and hammer. After that I vacuumed out the entire car (I'm a clean freak) and put it all back together. The new trunk release knob that i got from 1stsubaruparts.com was slightly a different shade (blue opposed to the original gray) but who the hell cares. :drunk:
