Loose crankshaft bolt?
11 replies to this topic
#1 Midwst
Midwst
    Subaru Fanatic!
  • 373 posts
  • Cedar Rapids
Posted 27 July 2005 - 06:24 AM
If a crankshaft bolt works loose and ruins the crankshaft, is the pulley and related parts still okay? Asking because I will be using some used parts on my engine job. I'm thinking they'd be fine, but wanted to check. Thanks.
#2 lmdew
lmdew
    _______
  • 3,560 posts
  • Colorado Springs
Posted 27 July 2005 - 08:17 AM
Most of the time they are damaged as well. Get used ones that are good.
#3 edrach
edrach
    RIP 6/28/14
  • 12,326 posts
  • Bothell, WA
Posted 27 July 2005 - 08:41 AM
The harmonic balancer and key are usually ruined before the crank's keyway is damaged.
#4 Midwst
Midwst
    Subaru Fanatic!
  • 373 posts
  • Cedar Rapids
Posted 27 July 2005 - 11:30 AM
Thanks guys. One other question: does the harmonic balancer part ever wear out? I know that on some GM cars, there is a rubber part in the harmonic balancer that starts to degrade/crack and wear out. I don't know if this is true for subaru.
#5 lmdew
lmdew
    _______
  • 3,560 posts
  • Colorado Springs
Posted 27 July 2005 - 06:08 PM
Solid metal no rubber or plastic
#6 avk
avk
    My Outback is bigger than yours
  • 965 posts
  • Somerset County, NJ
Posted 27 July 2005 - 06:41 PM
On my 2.2, the pulley is two-piece, with a rubber layer in between. The holes for factory crankshaft holder tool are in the inner piece.
#7 Midwst
Midwst
    Subaru Fanatic!
  • 373 posts
  • Cedar Rapids
Posted 27 July 2005 - 10:12 PM
I think it depends what year of 2.2L, Mine is a 1991.
#8 avk
avk
  • 965 posts
Posted 27 July 2005 - 10:23 PM
That thin rubber layer is hard to see, because of the shape of the pulley, the dirt, and limited view. But a '91 and a '95 may well be different.
#9 Midwst
Midwst
    Subaru Fanatic!
  • 373 posts
  • Cedar Rapids
Posted 28 July 2005 - 12:25 PM
The 95 uses different parts that the 91.
One more question, can the tensioner and idler pulleys be reused if the crank pulley came loose?
Thanks.
#10 avk
avk
  • 965 posts
Posted 28 July 2005 - 12:59 PM
Subaruparts shows same part number, 12305AA242, for both years.
#11 Midwst
Midwst
    Subaru Fanatic!
  • 373 posts
  • Cedar Rapids
Posted 28 July 2005 - 01:01 PM
avk, I guess that means that the rubber part can wear out? My car has 15 years and 187K miles!
#12 avk
avk
  • 965 posts
Posted 28 July 2005 - 01:37 PM
I don't know enough first-hand to tell how much risk there is. I remember looking at someone's Vanagon conversion site (can't find anymore) showing a salvaged EJ22 they bought with a broken pulley, and timing cover too as a result. As long as you have it off and verify it's a two-piece, might be a good idea to replace it.
