Ody Posted July 29, 2005 Share Posted July 29, 2005 Hey everyone, This is my first post and let me tell you...I am so impressed with the community here. Here's my problem - 2002 WRX Wagon: My rear wiper washer fluid doesn't work. I looked in the owners manual and it doesn't tell me where to fill up the rear washer with fluid. I press the button for the rear washer fluid and I can hear the pump, but no fluid... I'm sure someone here can help me out. Thanks! Quote Link to comment Share on other sites More sharing options...
kevinsUBARU Posted July 29, 2005 Share Posted July 29, 2005 Welcome! Does your front work? My guess is that you are out of fluid in your main reservoir since I am almost POSITIVE that they are both fed from the same reservoir in your engine bay. Start with checking that fluid level (on the driverside by the battery) and then look for a hose that might not be connected. Kevin Quote Link to comment Share on other sites More sharing options...
Ody Posted July 29, 2005 Author Share Posted July 29, 2005 Welcome! Does your front work? My guess is that you are out of fluid in your main reservoir since I am almost POSITIVE that they are both fed from the same reservoir in your engine bay. Start with checking that fluid level (on the driverside by the battery) and then look for a hose that might not be connected. Kevin My front ones work fine, and I've filled that thing up with fluid to make sure. I'll try looking for a hose that might not be connected, but I'm pretty sure I looked around there. I'll post again if its still not fixed. argh! Quote Link to comment Share on other sites More sharing options...
kevinsUBARU Posted July 30, 2005 Share Posted July 30, 2005 There should be two washer motors attached to the reservoir. I would start there, and then work towards the rear. I hope you find the problem! Kevin Quote Link to comment Share on other sites More sharing options...
Subie Gal Posted July 30, 2005 Share Posted July 30, 2005 they are both fed from the same reservoir up front did the reservoir ever run dry? is the rear nozzle clogged? if you can hear the motor... that's not the problem. it's got to be in the line or in the nozzle Jamie Quote Link to comment Share on other sites More sharing options...
