Guest Wagon Wagon Posted August 1, 2003 Share Posted August 1, 2003 Yes, sounds like a noob question, but I can't get a straight answer. The computer at the parts store says 3 quarts, I've seen some guys here mention 4 quarts, and the owner's manual says 7 quarts. So.... which one is right? I started going from lowest to highest. With 3 quarts in, after moving the lever through all the gears (I haven't driven the car yet) , the dipstick was right on the full mark. Yet the owners manual says to add 4 more quarts? Quote Link to comment Share on other sites More sharing options...
Guest Dennis Posted August 1, 2003 Share Posted August 1, 2003 7qts is capacity, probably if the torque converter was drained too... start with 3, run it, drive it, get it hot and check it again...4 is rightr if i remember correctly Quote Link to comment Share on other sites More sharing options...
