shiraz627 Posted August 7, 2005 Share Posted August 7, 2005 I have a 2000 Legacy L wagon with the 2.5L and Automatic transmission. The car has 111K miles. The problem I have is for a couple of weeks the transmission was slow to shift into drive from reverse, now it does not shift into drive at all only reverse. I checked the tranny fluid which is due to be changed and the fluid level was good but a little dirty as I have never changed the fluid. Any clues as to what might be the issue before I have it flatbedded to Subaru? Gary Quote Link to comment Share on other sites More sharing options...
Cougar Posted August 7, 2005 Share Posted August 7, 2005 Hopefully it is just sticky valves causing this to happen. There is a product called Auto-RX for transmissions that may help fix things up. Here is a link for you to check them out. http://auto-rx.net/ Quote Link to comment Share on other sites More sharing options...
