freedumbsnow Posted August 7, 2005 Share Posted August 7, 2005 I have a problem with my 02 subaru wrx wagon. I just bought and am happy with most results, however the rear running lights don't work fuses are ok I read a thread from 2003 to no avail. Any suggestions? Quote Link to comment Share on other sites More sharing options...
Cougar Posted August 7, 2005 Share Posted August 7, 2005 Have you checked for voltage getting to the lights? I assume that the brake lights are ok and if so, then that means the grounding to the lights should be ok. You will have to trace back the wiring to check for a bad connection somehow to the lights. Quote Link to comment Share on other sites More sharing options...
frag Posted August 7, 2005 Share Posted August 7, 2005 Have a look at this thread. It might contain the solution to your problem. http://www.ultimatesubaru.org/forum/showthread.php?t=30970&highlight=rear+lights+working Quote Link to comment Share on other sites More sharing options...
