PO325 Knock Sensor Code
6 replies to this topic
#1 mlebioda
mlebioda
    New User
  • Pip
  • 3 posts
  • Detroit
Posted 08 August 2005 - 03:58 PM
I have a 2000 Outback (91,000 miles) with a PO325 Knock Sensor Code. I changed my spark plugs, ingintion wires and PCV at 75,000 mile with Subaru parts. What are my next steps. If I need to order a new sensor what is the part number? What are the instructions to change it?
Thanks
#2 B99Brighton
B99Brighton
    New User
  • PipPip
  • 22 posts
  • foley
Posted 08 August 2005 - 09:15 PM
What motor is it? I know the knock sensor on my 99 2.2l isunder the drivers side intake manifold. It is held in place with one bolt and takes 5 min to change. Not sure on a 2.5l. I had mine fail a couple of years ago. Sorry i don't have a part #.
Thanks
#3 Cougar
Cougar
    Elite Master of the Subaru
  • 6,563 posts
  • Anchorage
Posted 08 August 2005 - 09:35 PM
Here is what the code definition is: Knock Sensor 1 Circuit Malfunction (Bank 1 or Single Sensor) .
You do need check the wiring to the sensor for a connection problem and probably replace the sensor. This is a dealer only item. They will know the right one you need from the year of the car. When installing a new one, do not over torque it.
#4 mlebioda
mlebioda
    New User
  • Pip
  • 3 posts
  • Detroit
Posted 09 August 2005 - 07:25 PM
Thanks for all your advice. I went to the Subaru deal and was able to get a "Sen Assy-Knock" #22060aa070 for $95. I found it on the drivers side by the maninfold. It took me about 10 minutes to install after the engine cooled down.
Thanks again,
#5 mattocs
mattocs
    Subaru Legacy Lover
  • 1,312 posts
  • Pittsburgh
Posted 09 August 2005 - 07:38 PM
I think my knock sensor was $22 at Autozone. It took about 3 minutes to install.
Good luck!
#6 jcrowley
jcrowley
    New User
  • Pip
  • 1 posts
  • Oklahoma City
Posted 09 August 2005 - 08:00 PM
Help! I have a 99 legacy L wagon (2.2l 5sp manual) and the CEL is on w/acocmpanying noise that is new.
Took it to mechanic who said it's the PO325 Knock Sensor Code - sent me to dealer. Dealer said it's d/t timing belt tensioner and wanted to charge me about a grand to fix it. Took it back to my mechanic who changed the timing belt and tensioner (for 1/3 the price) but didn't replace the sensor - b/c the engine noise wasn't fixed (but had improved).
My mech recommends either selling the vehicle OR having a new (to me) engine put it.
Any thoughts?? Thanks
Did also contact CCR Inc @ this
#7 Cougar
Cougar
  • 6,563 posts
  • Anchorage
Posted 09 August 2005 - 09:25 PM
To me this code indicates a problem with the sensor or the wiring to the sensor. If the wiring to it is ok then I think you should replace the sensor.
