Guest subarugsr Posted August 1, 2003 Share Posted August 1, 2003 im sorry im asking this stupid question, i am a tad under educated.. but what is SPFI an abbreviation for? S...P...Fuel Injection? Quote Link to comment Share on other sites More sharing options...
Guest slagathor1 Posted August 1, 2003 Share Posted August 1, 2003 SPFI is Single Point Fuel Injection..Basically injected at the carb..MPFI is Multi Point Fuel Injection, fuel is injected at multiple points directly into the intake manifold.. Tony in Illinois 89' DL retired 92' Loyale 4wd Quote Link to comment Share on other sites More sharing options...
Guest Adam N.D.J. Posted August 1, 2003 Share Posted August 1, 2003 It's Throttle Body Injection with a fancy name is all. There is one large injector in the throttle body, rather than injectors for each cylinder. It's pretty good though. I've got an 89 3-door with it, and I get about 450 miles to a tank, as opposed to my multipoint turbo that gets about 250 to a tank. It's good on fuel mileage, but not too great for power. Catch ya Laters. Quote Link to comment Share on other sites More sharing options...
Guest subarugsr Posted August 1, 2003 Share Posted August 1, 2003 so is SPFI, just carburetion? or is it a form of electronic injection? could i replace my twin carbs with twin SPFI or single SPFI? Quote Link to comment Share on other sites More sharing options...
Guest Flowmastered87GL Posted August 1, 2003 Share Posted August 1, 2003 twin carbs?? mmm gimmie!!!! Quote Link to comment Share on other sites More sharing options...
Guest subarugsr Posted August 1, 2003 Share Posted August 1, 2003 :lol: :rollin: :rollin: :rollin: :rollin: :rollin: :rollin: .. sorry mate i need them.. im actualy looking for a set of twin webers.. im in New Zealand... its not the easiest to find twin webers to fit a 1972 subaru GSR!! Quote Link to comment Share on other sites More sharing options...
Guest Adam N.D.J. Posted August 1, 2003 Share Posted August 1, 2003 It is electronic fuel injection, just more simple than the multiport (to an extent). You could replace a carb with it, but you would have to change the distributor, the intake, wire up the sensors and computer. A small feat for some people, a lifetime challenge for others. I was working on putting together a write up on how to convert from carb to SPFI for the EA81 people, but that has been pushed into the closet with a lot of other projects lately. I might look into starting that back up again. Catch ya Laters. Quote Link to comment Share on other sites More sharing options...
Guest GlCraigGT Posted August 1, 2003 Share Posted August 1, 2003 hey adam, i'm planning to convert my 84 wagon to SPFI or MPFI (using turbo heads) and running it with MegaSquirt for the ECU. The plus side is I can still use my stock ignition system and MegaSquirt uses MAP instead of MAF so there is no need for the tiny SPFI MAF. They down side is i would need buy and build the ECU kit then go through the tuning process. Quote Link to comment Share on other sites More sharing options...
Guest Adam N.D.J. Posted August 1, 2003 Share Posted August 1, 2003 Yeah, there are alway upsides and down sides to everything. I've check out the megasquirt link, looks like a pretty good system once everything is dialed in right. I was thinking of putting one together, as I like to tinker with electronics when I'm pretty bored. It's that liking for the electronic puzzles that spawned my putting the ER27 in the Brat. Catch ya Laters. Quote Link to comment Share on other sites More sharing options...
