Odd Coolant Leak - Driver's Side near Head
14 replies to this topic
#1 Mantonite
Mantonite
    USMB Regular
  • PipPipPip
  • 114 posts
  • Manton, MI
Posted 11 August 2005 - 08:31 PM
I have my freebie running fairly well, but after work today I noticed a puddle. It was coolant so I topped her off and headed home. She ran nice and cool (got her for free b/c she overheated: replaced thermostat and away we go), BUT I left a drip, drip, drip trail into the garage. :banghead:
Upon further investigation, it appears that it is leaking out of the timing belt cover/head area on the drivers side. It is "up high"; near the valve cover gasket area. Any clues on what this could be??? I plan on taking off the cover when I have time (have to go out of town tomorrow) but want input as to what I should be looking for. :confused:
Any ideas???
(first time posting picture... hope this works)
Edit - Thanks for the site... it has helped a TON so far!!! - End Edit
Posted Image
#2 Mantonite
Mantonite
    USMB Regular
  • PipPipPip
  • 114 posts
  • Manton, MI
Posted 11 August 2005 - 09:50 PM
UPDATE:
So while I should have been sleeping, or doing any one of many of my honey-dos I decided to dig a little deeper. A lot of good that did...
Took off the timing cover on the drivers side to see what I could see... nothing. Topped her off and ran her (idling)... no leak. So it appears that it's only when running.
BTW, the leak is near the cam. Does that help??? Anyone?
#3 Subi81
Subi81
    1000+ Super USER!
  • 1,009 posts
  • Ventura, Ca
Posted 12 August 2005 - 03:11 AM
make sure it is not the hose under the intake manifold, it could be leaking there then running into the sparkplug hole and out through the covers? Just a thought.
Good luck
#4 Hendrik
Hendrik
    USMB Regular
  • PipPipPip
  • 123 posts
  • Holland and Brazil
Posted 12 August 2005 - 04:08 AM
In my case it was the waterpump.
Underneath it has a "peeping whole" which than drops down in the drivers cover.
Feel if the pump has too much play.
If so replace.............
#5 Bucky92
Bucky92
    Drive Fast, Take Chances
  • 3,664 posts
  • New Milford
Posted 12 August 2005 - 04:28 AM
My Loyale has a similar leak..Mine is coming from the water pump ..but it is from the tube...needs a new gasket ( you know the metal tube on the upper side of the motor). I racked my brain for months trying to figure it out. But mine only really drips when the overflow/resevoir is full.
#6 Mantonite
Mantonite
    USMB Regular
  • PipPipPip
  • 114 posts
  • Manton, MI
Posted 12 August 2005 - 05:36 AM
The leak seems to be higher than the water pump, but I'll check it out.
BTW - I forgot to mention that the timing belt was dry - no coolant on it.
#7 Mantonite
Mantonite
    USMB Regular
  • PipPipPip
  • 114 posts
  • Manton, MI
Posted 12 August 2005 - 02:06 PM
Took a peek between runs at work and the top of the water pump is wet, near the weep hole. Guess it's time for a pump, unless anyone can think of another potential leak point.
#8 NorthWet
NorthWet
    Eeyore Incarnate
  • 5,039 posts
  • Bremerton, WA
Posted 12 August 2005 - 02:29 PM
As mentioned by Bucky92, it is possible that it is coming from the metal tube that is the water pump inlet from the radiator. It is above the pump centerline, and is a slip fit into the water pump with an o-ring seal. This seal occasionally fails to seal, and difficult-to-trace leaks occur.
Regarding the waterpump, is there a visible coolant-stained trail coming from the weep-hole? (All of my weep-holes are visible from the top of the engine.)
#9 thealleyboy
thealleyboy
    Subaru Derelict
  • 2,082 posts
  • Bexley, OH
Posted 12 August 2005 - 02:33 PM
Sometimes the h20 pump can be hard to diagnose.
Look at the color of the coolant that is dripping. If it is yellow/brownish, this is a sign that it is coming from the weep hole.
good luck, John
#10 Bucky92
Bucky92
  • 3,664 posts
  • New Milford
Posted 12 August 2005 - 03:03 PM
It does sound to me like you have the same leak as my Loyale does...not to complicated to fix..just needs a new O ring..the biggest pain is getting everything out of the way to do it...thats why mine isnt done yet :grin: ..one of the things on my to do list when I replace my timing belts.I just check my anti-freeze everytime I add oil (about once every week and a half). Put it this way...mine goes through a gallon of coolant about every 10 months or so...as long as I leave the overflow empty and the radiator full.
#11 Mantonite
Mantonite
    USMB Regular
  • PipPipPip
  • 114 posts
  • Manton, MI
Posted 12 August 2005 - 03:04 PM
How can I check it? Follow disassembly procedures and just replace the o-ring? Hopefully it'll be a visible leak on the way home so I can diagnose in the garage before I head out of town (in my truck).
As far as the color, it's hard to tell. There is oil everywhere on the engine so there is really no way to tell. There is no visible stream out of the weep hole; it's just wet all over the top of the pump... maybe that points to it being the metal tube. Hmmm...
#12 sregor13
sregor13
    Eat, Live, Breath Subaru
  • 345 posts
  • Lander
Posted 12 August 2005 - 03:13 PM
i just did this on my Loyale and make sure to gob your metal Tube going into the waterpump with RTV Sealant. The O-ring alone was not enough for me. I just gobbed the bad boy with RTV and seems to be fine now. Tha nks
#13 NorthWet
NorthWet
    Eeyore Incarnate
  • 5,039 posts
  • Bremerton, WA
Posted 12 August 2005 - 04:34 PM
Hot coolant coming out of the weep hole will clear away any oil, and leave a residue along the sides of the main trail. General wetness would tend to indicate another source. The inlet pipe is faily easy to remove, as long as you can get at the bracing bolt(s?). The o-ring is kind of odd/uncommon, so you may want to locate a replacement or commit to RTVing before you remove it.
It is also possible that the under-the-manifold hose might be leaking, and the leak just traveling along the top of the block to the wter pump area.
#14 Mantonite
Mantonite
    USMB Regular
  • PipPipPip
  • 114 posts
  • Manton, MI
Posted 12 August 2005 - 04:49 PM
NEW DEVELOPMENT
When I left work I took off the rad cap to top it off and much to my suprise the radiator was still pressurized even though it was bone cold. I bought a new cap and it doesn't seem to be leaking right now.
Could this possibly be the solution? The cooling system was getting overpressurized and pushing coolant out any way it could? I sure hope so.
I'll post with more next time I can drive it (likely Sunday).
#15 s'ko
s'ko
    RIP
  • 1,722 posts
  • Los Angeles
Posted 12 August 2005 - 06:32 PM
What Northwet said might be something you want to look into.
This is an EA81 so it may not apply, but I had a leak in the hose that went from the water pump to the metal piping under the manifold. I would be ok when the engine was running, but when it stopped it would leak.
I found out where it was when one day I turned off my car and when I came back a couple of mins later, it was peeing green fluid.
Good luck w/your leak.. :grin:
