sregor13 Posted August 12, 2005 Share Posted August 12, 2005 I now have a coolant leak from somewhere below the Turbo.. It is something Metal that has some lines coming off of it. It is almost directly below the Turbo and may be part of the engine itself. It a little bit in front of the Flywheel. It has some coolant lines that head back toward the cab of the car. Doea anyone know what this thing is called? iut appears to be leaking on the bottom side of this thing. Thanks Quote Link to comment Share on other sites More sharing options...
stephenw22 Posted August 12, 2005 Share Posted August 12, 2005 There's a rubber hose that is directly under the turbo. That (at least to me) would be the most likely source of a leak. Quote Link to comment Share on other sites More sharing options...
86subaru Posted August 13, 2005 Share Posted August 13, 2005 when you replace the coolant line also replace the oil line Quote Link to comment Share on other sites More sharing options...
MilesFox Posted August 13, 2005 Share Posted August 13, 2005 the metal line running from the head turns into a rubber hose under the turbo Quote Link to comment Share on other sites More sharing options...
sregor13 Posted August 13, 2005 Author Share Posted August 13, 2005 Well all I did was replace the thermostat and Gasket and have not seen any moe coolant leaking. Hope it does not return. Thanks! Quote Link to comment Share on other sites More sharing options...
