camber problem
8 replies to this topic
#1 Bad Brat84
Bad Brat84
    USMB Regular
  • PipPipPip
  • 35 posts
  • Aurora, CO
Posted 18 September 2003 - 10:25 PM
The camber on my 84 Brat is worse now and has worn through to the cords on the passenger side front tire. Driver side is bad but liveable. I know there is not any factory adjustment for this and I know it is a common issue. I know I'm not the first with the problem but I can't find any old post on this or anything in the USRM. Any suggestions before I replace the tires? It has adjustable shocks and they are all the way down.
#2 Hodaka Rider
Hodaka Rider
    Original BC Soobnut
  • 1,577 posts
  • Nelson, BC (Canada)
Posted 18 September 2003 - 11:23 PM
Is the tire worn on the outside edge, or the inside edge?
#3 Bad Brat84
Bad Brat84
    USMB Regular
  • PipPipPip
  • 35 posts
  • Aurora, CO
Posted 19 September 2003 - 07:59 AM
It is worn on the outside edge which seems typical for this vintage Subaru. It is visible to the eye why the tires wear on the outside \ / .
#4 JonOfScio
JonOfScio
    OMGZ!!! HATCH ATTACK!
  • 713 posts
  • Corvallis, OR
Posted 19 September 2003 - 08:32 AM
if your car lifted?
#5 archemitis
archemitis
    guy smiley
  • 3,554 posts
  • the big minnie
Posted 19 September 2003 - 09:33 AM
mine does that with the adjustable shocks cranked. would the wrong shocks do it guys? what about crappy worn to hell ball joints.
#6 Bad Brat84
Bad Brat84
    USMB Regular
  • PipPipPip
  • 35 posts
  • Aurora, CO
Posted 19 September 2003 - 02:08 PM
it was worse with the shocks cranked to raise the front end but they are all the way back down now. I checked the suspension and noticed the ball joint is in the correct spot to affect the camber but felt like it was still tight. I know I saw some old post with someone who made changes at the top of the strut to give some adjustments. But what would change so much to make it necessary?
#7 Bad Brat84
Bad Brat84
    USMB Regular
  • PipPipPip
  • 35 posts
  • Aurora, CO
Posted 20 September 2003 - 08:25 AM
anybody? I know there have been alot of comments and suggestions on this before so I'll bump it back up.
#8 Guest_subu luvr_*
Guest_subu luvr_*
  • Guests
Posted 20 September 2003 - 09:08 AM
when i replaced the struts in the hatch, i saw atop the
upper spring perch, something about "this way" for 2wd
and "that way" for 4x4.
i believe you rotate the top of the strut 180 degrees
dont quote me, but have a look at the top of your strut
and see if you see any markings.
i will go look at the spares i have.
and even if i am wrong, you can slot the top strut mount holes
to let you move the top of the strut inwards, toward the motor,
thus correcting the camber
#9 GeneralDisorder
GeneralDisorder
    Elite Master of the Subaru
  • 20,371 posts
  • Portland
Posted 20 September 2003 - 09:11 AM
Pull your ball joints out and check them. Check the lower control arm bushings maybe? Wheel Bearings?
I think I would probably just tear one side of the suspension down, and see what is in there.... something is wore out.
