Skip Posted September 19, 2003 Share Posted September 19, 2003 87 turbo wagon 4wd 5 speed (James Bond button) She has a Bythesea built short throw shifter (w/Hurst "T" handle) Redline NS gear oil. I am about out of mods I can make to this lump aside from the flux cap. and maybe a bigger turbo Alas she is still a Suba-toad Any ideas? Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted September 19, 2003 Share Posted September 19, 2003 WOW! All that and she's still too slow for you skipper? Good lord, maybe it's time for an EJ? How about using an NA long block to up your compression? How about an aftermarket Fuel Injection system - something programmable? Custom intake might be nice too. Forged pistons? billet steel crank? custom cam? GD Quote Link to comment Share on other sites More sharing options...
JonOfScio Posted September 19, 2003 Share Posted September 19, 2003 higher octane/advanced timing (you probably are doing this, but I don't see it specifically listed as such) For a good sound and performance, go with some new bigger performance cams. Go for that "I'm idling, I sound like a muscle car, and I'm about to die" sound. you could do some NA pistons... or hell, if 1600 pistons will fit, go for that. I'm sure it'd boost the CR well over 10:1. In an ea81 it puts them at 9.5:1, so imagine in the EA82 what would happen. I think the NA EA82 is already 9.5:1. Anyhow, not much for the turbo car I guess... you could do a twin turbo setup, one on each side. I'm guessing your not running with any cats? (cats are bad... m'kay?) Quote Link to comment Share on other sites More sharing options...
gravelRX Posted September 19, 2003 Share Posted September 19, 2003 Likes? Dislikes? Curious, Jay Quote Link to comment Share on other sites More sharing options...
baccaruda Posted September 19, 2003 Share Posted September 19, 2003 Hey Skip. How fast exactly is your car? Maybe larger injectors would work? Maybe it's time for some dyno work. You might also try trolling the ausubaru.com board.. the aussies seem to hot rod their EA82Ts harder than we do over here... Quote Link to comment Share on other sites More sharing options...
offroadsubaruguy Posted September 19, 2003 Share Posted September 19, 2003 i hear for daily driving, a lightened fly wheel is not a good idea.... because you will actually accelerate slower between 1-3,000 rps because there is no mass to get movng, but after that, your good....... just what i hear, not to be held as pure truth..... Quote Link to comment Share on other sites More sharing options...
gravelRX Posted September 19, 2003 Share Posted September 19, 2003 thanks for the info, but looking for 1st hand experience from someone that has a compatable car to the one I own. Jay Quote Link to comment Share on other sites More sharing options...
Skip Posted September 19, 2003 Author Share Posted September 19, 2003 thanks for looking and for the suggs I really do not want to tear her down, I have a couple extra EA82Ts I could build - again thanks for the reccos I have a G-Tec PRO but do not have an accurate weight on the wagon. Will get to a weigh station soon. On the lightened flywheel, sorry I have to disagree with Offroad She seems to spin up faster due to the lower angular momentum I can't get to the gear shift fast enough if I stand on the loud pedal in first gear. But I do not like the drive line shock hitting second hard so I shift at about 5.7 k Now in second and third -7 grand and it's still pulling hard - ask Trogdor The problem I thought I might have is starting from a stop, but that is not the case, she pulls out just fine. Even with a 1000 lb trailer behind. Now where an I gonna fit the flux capacitor? On the dash? see other post Quote Link to comment Share on other sites More sharing options...
oddcomp Posted September 20, 2003 Share Posted September 20, 2003 yeah adding cams would be a good idea if it was n/a runnign those lumpy cams ona turbo motor you will losae alot of power cause of valve overlap not enough exhaust rpessure to spint eh turbo up like it should now if possibly you had a set custom ground for your turbo engine by a person or compnay with experience in say turbo vw's? then you might get somewhere Quote Link to comment Share on other sites More sharing options...
Skip Posted September 22, 2003 Author Share Posted September 22, 2003 Oddcomp, cams are a doable project does anyone remember the company that was doin regrinds at a reasonable price (like 50 or 60 bucks a side)? Quote Link to comment Share on other sites More sharing options...
bushbasher Posted September 22, 2003 Share Posted September 22, 2003 put xt struts/shocks or whatever in it, to drop it a few. Still a toad as in not making the hp it should be or not enough for you? how many k on the motor? Maybe disconnect the ac? On the flywheel, a lighter one will spin up faster with no load, and a bit faster under acceleration (that all depends what is slowing the car... not enough hp or too much rotating mass). A light flywheel is fine once you are moving, but a larger rotating mass helps jerk the car forwards initially when you dump the clutch from a stop. With a really light flywheel you have to rev higher, in order to drop the clutch fast and not stall. Maybe only a little though. Quote Link to comment Share on other sites More sharing options...
scoobie steve Posted April 13, 2004 Share Posted April 13, 2004 Raising the compresion is NOT good for making more HP in a turbo engine. 8:1 is ideal on most turbo engines. There is only one true way to make big hp with a turbo engine, A BIG TURBO! lots of boost. Cams might be good for 10-20hp, not worth the hassle. Pull that turbo off and put a vf22 on there. With enough fuel 300whp is very possible. Prolly wont last long at that hp level. Quote Link to comment Share on other sites More sharing options...
subarurx Posted April 14, 2004 Share Posted April 14, 2004 heres my 2c worth: you could go for a fmic using the starion one, wouldn't be too hard to do, and with the fans running behind a new Legacy radiator, you would have a lot of cooler air flow, and not much heatsoak, and the car will run cooler. Quote Link to comment Share on other sites More sharing options...
subarurx Posted April 14, 2004 Share Posted April 14, 2004 oh yeah, and a ea82 full time box with a impreza wrx ra gearkit, 4.11 diff on the rear, top speed 180km/hr, and you get there very fast, my Rx certainly does...took it out for a run in the weekend, running 14psi, forged pistons, FMIC, legacy radiator etc. etc, and holy subaru...it's quicker than my old stock Mitsubishi Glant VR4....have a rally on tarmac on the 24ht of this month, in New Plymouth, New Zeland, 200km of competitive stages...can you tell I am excited... back to the topic, not sure how they did the gearbox, but it is fantastic Quote Link to comment Share on other sites More sharing options...
Flow Posted April 14, 2004 Share Posted April 14, 2004 Oddcomp, cams are a doable project does anyone remember the company that was doin regrinds at a reasonable price (like 50 or 60 bucks a side)? I think you want delta cams out here in Tacoma, Wa. As for your next mod... I didn't see a hula dancer on the dash. Quote Link to comment Share on other sites More sharing options...
oddcomp Posted April 14, 2004 Share Posted April 14, 2004 raising compresion is just fine even with a turbo motor it helps alot in non boosted cruise for economy you have to use the right hardware like me i am instlaling a saab apc system that back down teh boost anytime it hears detonation hehe plus i dug up a bunch more automatic boost controll schematics and some other stuff that will drive up 4 or 5 additional injectors depending on the amount of boost the system see's weee Quote Link to comment Share on other sites More sharing options...
josh long Posted April 14, 2004 Share Posted April 14, 2004 Now where an I gonna fit the flux capacitor? On the dash? see other post 1.21 jiggawatts Skipper you must be CRAZY! What turbo and how much boost are you running? Your exhaust is 3" right? fuel pump? base fuel pressure? and variation at max boost? Josh Quote Link to comment Share on other sites More sharing options...
