Cracked heads...
16 replies to this topic
#1 TurboSPFI
TurboSPFI
    Banned
  • Banned
  • 374 posts
Posted 15 August 2005 - 10:18 AM
Well, Ive fully pimped out my cooling system including a headgasket job to find out that I have cracked heads... pretty nasty cracks inbetween the intake and exhaust valves...
So, what should I do? I hear brand new loaded heads are about 250$? per side... Should I cough up the 500$ plus whatever it costs to get the delta cams or just run this motor until it dies?
I guess the question is.. would it be worth it to get some virgin heads with some new cams?
#2 88rxsedan
88rxsedan
    Subaru Fanatic!
  • 385 posts
  • san antionio
Posted 15 August 2005 - 10:34 AM
the small crack in between the valves is normal, even with gen 3 heads..
ive seen several cracked with no performance degredation..
could you post a picture of it for further analysis
#3 TurboSPFI
TurboSPFI
    Banned
  • Banned
  • 374 posts
Posted 15 August 2005 - 11:00 AM
Nah, I've already reasealed my engine... I still have the bubbles in my coolant which I'm almost sure comes from that dept.
#4 NorthWet
NorthWet
    Eeyore Incarnate
  • 5,039 posts
  • Bremerton, WA
Posted 15 August 2005 - 12:38 PM
I would seriously doubt that those cracks reach into the water jacket. Generally (speaking non-soob-specific), those cracks bridge the intake and exhaust ports and/or cause issues with the valve seat inserts. Without bandsawing the head apart, I would guess that the nearest that the water jacket gets to the valve seat bridge area is about 1/2 inch... that would be a very deep crack, and the car would show other problems first.
#5 MorganM
MorganM
    Do you Subaru?
  • 8,390 posts
  • TwinCities
Posted 15 August 2005 - 01:54 PM
Yes I would suspect cracks somewhere else. Not between the valves like you noticed but rather deep in the exhuast port where they actually can crack into a water jacket. Cracks can be hard to see with the eye. I have heads pressure tested by a machine shop to see if they are realy cracked or not.
#6 Steveman09
Steveman09
    Subaru Fanatic!
  • 420 posts
  • Portland
Posted 15 August 2005 - 02:01 PM
When I rebuilt my EA82 I too had the big cracks between the valves on both heads, I then ported the heads out even bigger and had them pressure tested to extreme PSI and they passed with flying colors.
No problems.
#7 TurboSPFI
TurboSPFI
    Banned
  • Banned
  • 374 posts
Posted 15 August 2005 - 03:19 PM
Dang, the things I should have done BEFORE I resealed the motor.. oh well, I was on a timeframe.
#8 NorthWet
NorthWet
    Eeyore Incarnate
  • 5,039 posts
  • Bremerton, WA
Posted 15 August 2005 - 04:14 PM
BTW, you might want to consider getting rebuilt heads. CCR is an option, as is at least one place in the Seattle/Tacoma area and at least one in Portland, Oregon. The semi-quote that I heard a year ago for turbo heads from a local rebuilder was around US$230-250 a pair. (Don't know about SPFI, but should be nearly the same price.) By the time you pay to pressure-test, surface the head, and do a valve-job, you are probably looking at more than that cost.
#9 TurboSPFI
TurboSPFI
    Banned
  • Banned
  • 374 posts
Posted 15 August 2005 - 07:04 PM
I'm not talking about rebuilt.
#10 NorthWet
NorthWet
    Eeyore Incarnate
  • 5,039 posts
  • Bremerton, WA
Posted 15 August 2005 - 08:47 PM
I understood that. I was offering up rebuilts as a very viable option.
#11 TurboSPFI
TurboSPFI
    Banned
  • Banned
  • 374 posts
Posted 15 August 2005 - 11:16 PM
OK thanks... :-\
#12 MorganM
MorganM
    Do you Subaru?
  • 8,390 posts
  • TwinCities
Posted 16 August 2005 - 08:30 AM
Where did you get that quote? All the $200 to $300 heads I found were remands. I paid about $400 for a brand new one from SOA.
#13 ausubaru92
ausubaru92
    Turbo Talker
  • 583 posts
  • Bowraville NSW Australia
Posted 16 August 2005 - 04:53 PM
This is from a technical service bulletin stating that cracks between the valves are ok
Gannon
#14 TurboSPFI
TurboSPFI
    Banned
  • Banned
  • 374 posts
Posted 16 August 2005 - 05:00 PM
OO! Thanks ausubaru!! thats the info i needed right there... no spending money for me yay yay yay :banana:
#15 Dirk
Dirk
    Lazy Perfectionist
  • 486 posts
  • Wanaka New Zealand
Posted 21 April 2011 - 04:31 AM
Thanks from me too.
#16 jeffast
jeffast
    f*** im 24
  • 2,029 posts
  • midwestren
Posted 21 April 2011 - 08:31 AM
OK thanks... :-\
if you do consider going with rebuilt heads i would use retro roo
http://www.retroroo.com/
he specializes in 79 through 95 subarus
edit: wow, didnt read the original post date on this one lol at me
#17 Dirk
Dirk
    Lazy Perfectionist
  • 486 posts
Posted 22 April 2011 - 01:25 PM
For those who are interested.
Posted Image
