88 spfi wagon occationally hunts for idle
5 replies to this topic
#1 Guest_subu luvr_*
Guest_subu luvr_*
  • Guests
Posted 19 September 2003 - 10:40 AM
sitting at stoplight, idling smooth, occationally
it revs up 200 rpm then drops back to where it was
in a 3-5 second cycle
any ideas? going out to pull the codes now
#2 Scrub2k
    Eat, Live, Breath Subaru
  • 273 posts
  • Reno
Posted 19 September 2003 - 11:30 AM
Sounds like you have a vaccum leak to me, i'd check all of your vaccum lines, my honda did the exact same thing when i had a cracked vaccum line.
#3 c150L
    Subaru Nut
  • 532 posts
  • East Central Wisconsin
Posted 19 September 2003 - 02:05 PM
Might want to check the putor codes if you get bored. I thought someone once said that a bad connection on the the engine coolant temp sending unit can raise havoc. Could the air conditioning have anything to do with it? Don't think it was a Sube, but I remember a car that the idle would spike up just a bit before the AC compressor would kick in. Then the putor would again calculate out the correct idle speed. Just guessing for you.
#4 c150L
    Subaru Nut
  • 532 posts
Posted 19 September 2003 - 02:06 PM
Careful with those vacuum lines and plastic fittings. You remember! LOL
#5 archemitis
    guy smiley
  • 3,554 posts
  • the big minnie
Posted 19 September 2003 - 06:07 PM
that thing always did that, even with the other motor. i think its the idle air controll valve sticking. b12 chemtool helps it go away for a while
#6 Guest_subu luvr_*
Guest_subu luvr_*
  • Guests
Posted 19 September 2003 - 06:16 PM
thankie, i will try that
